mistafosta
About mistafosta
  • Birthday 08/31/1981
Contact Methods
  • AIM
    mista240z
  • Gender
    Not Telling
  • Location
    Pleasant hill, california
Recent Profile Visitors
mistafosta's Achievements
Newbie
10
  1. Even on a stock engine. Weight is different, exhaust/intake are totally different, and you have all the smog stuff removed. Car needs a tune without question. It may not be the only source of your bad gas mileage but I'm willing to bet its a large part of it.
  2. Totally understandable. If I had an extra set laying around, I'd send them your way, but ls7 heads are few and far between
  3. Cannot stress this enough, but you need a quality tune. A crappy tune will cause terrible mileage and a myriad of other issues, and oftentimes they turn off the CELs that would normally turn on as a result. Get it tuned on a dyno and street by a competent local tuner, and you will see a ton of difference.
  4. So how much would it cost me to get you to make me an ls7 version of that intake?
  5. Great choice in setup, sounds like an extremely reasonable setup.
  6. Did a few more things to the car, started dialing in the suspension, and added wheelie bars to be safe, since this car likes to climb when it hooks. 3 hours before going to the track, found a bit of a problem. Seems I sucked a zip tie or something down my turbo while on the dyno... Lucky for me, my buddy had a twin of it, so we swapped it out, and headed to the track. Spent a long time chasing electrical gremlins, (Ended up having a bad cell in my optima...) and then finally got the car out there to make a nice easy A to B pass. Needless to say, car went a bit faster than expected considering I didn't have the boost up very high, and it was leaving at 3lbs of boost and 3400rpm. Got the car to leave later in the evening, but the clocks were off, so I have no idea what it ran. According to my logs, I passed the 1/8 around 140+. Excited to make it back out again in a few months! Just picked up a sponsor who is setting me up with a Holley Dominator system to get the car working even better!
  7. Gonna need to turn that thing up to kill +10 to get that record hehe
  8. 427 ci LSX block with 265cc heads and a fairly big cam (250s duration, 650+ lift). It was being held back by the turbo size to engine size issue for this dyno session, and the fact that I couldn't get any more boost without co2 which I don't have installed yet. Stay tuned for a new turbo, I got a screaming deal on a GT5533, so I'm gonna swap that in next month, and hopefully we can see a bit more power on the dyno
  9. https://youtu.be/mQ8T7sKmsz4 Thanks to Nate and Starkweather tuning, we were able to get a nice base tune on the car. Found out I need co2 to get over 15lbs of boost with this tiny turbo though! Still, made good power for 15lbs of boost. Looking forward to making some passes in the next month or two, and maybe getting back on the dyno with 5-10psi more boost!
  10. Just use isolation mounts, should be fine. You should always use those for fuel pumps anyways, so its no big change.
  11. Looks good man, I'm excited to see the results of this setup. I may be going glide once I go larger turbo, and I will for SURE get a GVOD. (They can hold 1600+hp right?)
  12. That sucks. I've run into a few bad headlight/ts switch assemblies. Theres a guy that rebuilds them for a reasonable price I'm pretty sure. I recently got lucky and picked up a mint 78 280z steering assembly and swapped the entire ignition/HL/Tss switch over from it. But before that, I went through 2 factory 240z HL switches.
  13. If the engine isn't running and voltage is a little low, quite often ONE side of the HIDs will not work.
  14. New motor is alive! Sounds great, drives nice. It runs a little warmer (About 10-15 degrees max) but its an iron block 427 vs an aluminum block 402, so its understandable. Didn't have time to tune it this trip, but I'll get it dropped off for that within the month most likely. Excuse the mess, I'm a slob when I'm working on this car. Mostly due to trying to get weeks worth of work done in days.... Ironically after all that, I forgot to take a picture of the new hood installed. I now have a cowl induction hood, and I'm contemplating installing the vents from my old hood on it.
  15. This setup really only works if you don't plan on making 600+hp and are using the factory corvette filter/regulator setup. Otherwise its not a good idea.
