68
Here's the response I got from the zhome mailing list to my "Does header wrap cause overheating" question: "When I crewed for a Z car that was racing SCCA nationals in the 1970's in the NE, we started to wrap the headers and immediately experienced blown head gaskets. Consulting with the header manufacture, they indicated that wrapping headers does what the product is designed to do, reduce heat in the engine bay. However, as an unwanted byproduct, the the wrap also backs heat up into the head. Too much heat and the head warps blowing the head gasket. To correct, remove the header wrapper. If you need to keep heat from the carbs, build a heat shield between the headers and the carbs." Thought this might be of interest for anyone else considering a bad purchase... Jon Mortensen
wierd brake issue - not my Z - Dakota Pickup
JMortensen replied to boatbum's topic in Brakes, Wheels, Suspension and Chassis
Sounds like a bad master cylinder. Its been a while since auto shop, but I believe the primary cup (?) is the name of the seal that actually pushes the fluid. If the front primary cup goes bad, the fluid can pass the secondary cup and return to the reservoir, without actually exiting the system. If the rear primary cup blows it will usually leak brake fluid into the booster. You can look for a leak at the back of the master and see if there is fluid there (usually seeps). Put light pressure on the pedal, hold it there. If the pedal slowly sinks to floor, then the master is bad. Its not a bad idea to check for other leaks like wheel cylinders and calipers, but you said the level was the same, so I'm thinking the master is the culprit... Jon Mortensen -
installing sway bars
JMortensen replied to David K's topic in Brakes, Wheels, Suspension and Chassis
If you want to take the preload out of the swaybars you can drive around as planned then loosen both ends. Sit in the car, and have someone else do the work because your weight is important here. One end of the sway bar end will touch the end link, the other will be probably 3/8 to 1/2 inch from touching. Put a stack of flat washers on the side that is higher so that both bar ends touch the end links at the same time. Then tighten as usual. If you don't do this then the bar is constantly preloaded, which is not noticeable by most but will tend to make the car feel different when turning left vs right. Jon Mortensen -
You have a 240, but you didn't list what engine you have. Assuming you've got a 2.4, I'd say 40's are OK. Anything bigger and I'd go 44 Mikunis or 45 Webers. Don't do it if you cannot tune a carb or don't want to spend money on jets. They're a big PITA if you are unfamiliar. Get the How to Modify book, it goes through all the circuits on the carbs, and get a one wire O2 sensor mounted in the exhaust manifold/header. With the O2 sensor you know exactly what the air/fuel ratio is. Just hook up a volt meter to the O2 sensor. You want voltage to equal about .85 - .9 volts for best power. Also make sure you have enough cam to take advantage of the carbs. I've got a friend running a basically stock L20B on a 510 with dual 44's. He can't rev over 6K, because of the cam. But the velocity of the incoming air is so slow at low rpms that he really doesn't have much low end either. So he has the worst of both worlds. No bottom end and flattens out really bad on top end. On the plus side I've got 3 x 44's and a fairly big cam and a light flywheel and I can drive in stop and go all day long (except for my new overheating prob--totally unrelated). People often warned me not to do the triples because I would hate driving in traffic. Same thing with the cam. Same with the light flywheel. And the ACT pressure plate. People generally just told me not to do to my car what I've done to it. My experience has been that the L6 has enough low end torque to offset the all of these potential problems, and I love the way my car drives! Jon Mortensen
I cc'd my head and polished the combustion chambers and did a little port work myself. It is not that hard. And the How to Modify book helped me A LOT. First thing I did was lay the head gasket down on the head and trace out the pattern. Then I unshrouded the valves to the fire ring line. When I had all of these done, I took a piece of Lexan and cut it so that it fit over one combustion chamber. I drilled a hole in the Lexan, then filled the chamber with water from a graduated cylinder. I did have to drill some vent holes with a pin drill to get the air out of the chambers. I kept grinding away on the chambers one by one until I got all of the chambers within .5 cc. I even went further and notched the block to match the head so that there was as much open space around the side of the valve for air/fuel to get by as possible. As far as ports are concerned, I did a lot of smoothing on the short side radius with my finger and a piece of sandpaper, but the bowls and the runners were already pretty good, since they had been worked on previously, so I cant give you too much there. So you're not flow testing. At least you know that the chambers are the right size and shape, and that you've removed all of the sharp edges in there. Datsun ports are pretty good anyhow. I would match the gasket to the head and the manifolds, clean up the big errors in the casting of the runners, then work on the chambers. Jon Mortensen
The reason we use pressurized cooling systems is to keep the water from boiling. We mix antifreeze and water because water transfers heat a lot better than antifreeze, and antifreeze has a higher boiling point and provides corrosion protection. If you use a liquid that doesn't boil until 370 degrees, then you don't need a pressurized cap to keep it a liquid (pressure raises the boiling point in a conventional system). I question the cost ($25/gallon) and the heat transfer effectiveness of that fluid. I'm not saying it isn't better than what we normally use, but I saw nothing on their site about the heat transfer properties vs. water, only the size of vapor bubbles comparison. I suppose you could just buy 5 gallons or so ($$$) and have some on hand, but it would be expensive when you spring a leak and need to fill the system, or need to remove the radiator for some reason. I also don't know where to get a 4 lb. radiator cap for my Z to take advantage of the longer hose life they offer. Hoses aren't that expensive either, so you could replace a few of them before you actually saved money by spending 10 times the price for coolant - since you don't mix 50/50 you gotta fill the WHOLE SYSTEM at $25/gallon. One thing they say that kinda bugs is that your engine can get up to 250 degrees without the coolant boiling. WOW! Never mind that warped head, I'm gonna run at 250! Now I know that newer Vettes have a 245 degree thermostat, and that increases fuel economy, but I don't think our Datsun equipment is designed for that kind of heat, and I think we can all agree that you don't make the best power at that temp. The whole thing reminds me of the synthetic oil commercials: "Look how regular oil gets all crusty at 450 degrees." Hello??? If your oil is 450 degrees you have some other problems!!! Always a skeptic, Jon Mortensen
Z Car getting hot... radiator probs???
JMortensen replied to JMortensen's topic in Trouble Shooting / General Engine
14" puller. Got rid of clutch fan a while ago. Triggered by Nissan temp switch in lower rad hose from 240SX. The weird thing now is that it cools fine under hard usage. It gets hot when idling. I think I'm going to take the wrap off and see what happens. The one thing that always gets my panties in a wad is wasting money on $*&! that doesn't work. If nothing else I suppose this has been a nice commercial for Jet Hot. I don't think a coated header would pass nearly that amount of heat to the head. Thanks all, I'll update you on the situation when I get that crap off. Jon -
What again is this supposed to be for? You want me to take a reading of the plugs at cruise (like plug color), or the radiator temps? I know that the way the air/fuel isn't the issue. The O2 sensor read about .85 to .9 volts at 65, so thats about 13:1 to 12:1 air/fuel ratio. Since I've switched to the AVGAS I would have to pull plugs and check color to get air/fuel, but I'm no plug reading expert, so I think the O2 is going to be WAY more accurate in this instance. The only difference in the cooling of the car occurs when I am stopped. When I'm moving the car never gets hot. That's why its so confusing. You would think that with my foot in the gas the thing would get hot because I would be putting a lot more heat out at that point. But it seems to be only when I'm idling that I have a problem. I would be happy to check a plug, but I wanna know what you're looking for... Jon Mortensen -
With relation to fuel I forgot to say that I've been mixing 92 octane alternately with Tolulene and AV Gas to get around 95 octane. Tolulene when I was tuning the carbs, AV Gas after the tuning was done. And yes, I know that AV Gas runs a little leaner than regular fuel... Jon Mortensen -
I just caught your question as to where I'm from. Grew up in SoCal, lived in San Luis Obispo for 6 years, then just moved to Seattle area. Why I chose that thermostat: Prior to this the car would barely ever see 195 degrees. According to "How to Hotrod" the L series makes power there, and if I put in a 175 thermostat, the engine would see 180 maybe 5% of its life. You could watch the thermostat open and close on the temp gauge. I haven't yet found a thermostat that opens at the temp on the box. Even this 195 that I just put in opened at about 187. But that is the reason. Maybe a cooler thermostat wouldn't be a bad idea, although I don't know if it will prevent me from having to take the wrap off. I think the wrap experiment has been an expensive waste of time. -
The only thing I did other than the header wrap is to rebuild the distributor. That's all. I just replaced the thermostat as well, with a 195 degree thermostat. I chose this thermostat based on the "How to Hotrod" book. Apparently the L6 makes max power about there. I would be curious to see what other members are getting down the radiator at idle. Thanks again, Jon Mortensen -
Thanks for the welcome. I've been on the zhome list for years, but I always thought this was strictly V8 conversions, so I never checked this place out. VERRRRRRRRRRY COOL. Shoulda been here years ago. As to the state of tune, I guess I could have provided more info. No detonation at this time. I tuned the Mikunis with an O2 sensor, so I know they're pretty close to right. I was always taught that if you made a change and had a problem, than that last change is your likely suspect, but since header wrap is such a weird thing to cause overheating (and I thought that the gasket would insulate the heat to some degree), so I was just going to run it by everyone to get some opinions. Seems like you agree with me on the last change bit, but I am still having a hard time imagining that wrap is the issue. Here's the gist of the motor: 280ZX flattop block E31 head 11:1 compression .490 / 280 cam newly rebuilt electronic dizzy D6K8 from 280ZX 15 degrees static advance, no vacuum 3x 44 Mikunis (didn't change any jetting while I was working on the car) MSA header MSD Mechanical Autometer gauge (pretty confident that its not a gauge problem) 240SX fan switch in lower rad hose comes on at 100 degrees C, gauge agrees that that is what it is doing The radiator is a 3 core 280 I got it 2 years ago in a parts car, and it was brand spankin at that time. Does that help? Thanks everyone, Jon Mortensen -
I recently installed header wrap on my Z and when I put it back together the water temps have been really high. This car used to very rarely use the fan at all, now the fan is on all the time. I was thinking about this some more and figured that it is highly unlikely that the wrap was the culprit, so I did a little more investigating. I took my infrared pyrometer and got the car warmed up, then took some readings on the radiator while it was idling. I found that it seemed to be able to hold about 205-210 degrees steady. When using the pyrometer, I found that I had about 205 all across the top of the radiator, and about 195-200 at the bottom. This was on both sides of the radiator. When the fan came on the area directly hit by it was 205 top and about 150 where the fan was sucking. I was looking for a cold spot, somewhere where the radiator was blocked possibly. Did not find it. It seems to me that the other part of the radiator (where the fan isn't) should do more than 5-10 degrees worth of cooling, even if there is no airflow. Is this right? Is the radiator just partially clogged and not capable of doing its job? Anyone suggest any other checks or tests I can do? Thanks in advance, Jon Mortensen
guys that have coilovers....
JMortensen replied to a topic in Brakes, Wheels, Suspension and Chassis
Doug, Every coilover and camber plate is different. Given that Mike only wants to go down 2 inches, and my plates don't use the stock hat so they already lower the car over an inch, if he used similar plates he would not be able to section the strut and only go 2 inches below stock unless he made a spacer to sit on top of the strut assy. If you section 2 inches, and the plate gives an inch and a half, that puts you well below where Mike wanted to be. I also have a 240 and I am running 200# and 250# springs. I would think that sag should be at least 1/3 of the travel, if not a little more. Sorry, I don't have anything to back this up, just my previous years of tuning suspensions on motorcycles and cars. To be honest, even when I was prepping Porsches (just the local Porsche shop, but great experience aligning, corner weighting, modifying) no one ever asked for a specific sag setting. But those cars all ran really low and there was no point. I agree that sectioning the struts is a VERY GOOD IDEA when your car is being run at a significantly low ride height. Tom Holt has a picture of his car with sectioned struts in the full droop position http://www.ccsi.com/~tholt/shocks.htm. In the rear full droop is with the control arms only very slightly pointing down. This is not enough droop for a road car IMO, and apparently not enough for him either. He also states that he has 1 1/2" of sag. I would argue that a little more than that would be preferable for the road. In a race car (especially road race) you don't need 12 inches of travel. A smaller amount of travel with extreme control over its movement is the goal. Plus if you go past horizontal with the control arms your camber changes positively when you load the suspension. From what I have been taught it is also easier for G forces to compress the suspension with the arm pointing up than when it points down. I don't think that sectioning the struts is as necessary as some. I've never heard of people buying Euro springs or Eibach progressives then sectioning the struts to regain travel. I don't know why this would be more necessary on a coilover setup that is being used to lower a Z 2 inches. My $.02, Jon Mortensen -
Find a 60's to 80's Nissan truck with L series motor. Take the shifter from that, bend if necessary in a hydraulic press, cut to length, thread for shift knob. Cheap and not so easy $5 short shifter. Jon Mortensen
I just installed some header wrap on my MSA header. I did this because I thought it would keep the 3x Mikunis cooler, and because I hate the header with a passion (had to weld on it just to get it to seal to the head, tubes are really crushed down inside coming out of the head, etc.). I want it to burn up so I can justify something better to the wife. My engine has NEVER had any problems overheating, even during track days at 100+. When I test drove the car I found that the wrap made quite a difference in noise, but seemingly little difference with regard to the heat, and the car suddenly seems to be creeping up in temp when sitting at stoplights. It used to be that my electric fan would RARELY come on. Now its on the perma-fan setting, and it can't bring the temp back down. Sitting in traffic when its 90 with the heat going SUCKS Is it possible that the wrap is the problem? Anyone experienced this before?
For brake fittings: Get a cheap flare nut wrench. Cut the end off. Grind notches along the outside. Slide the end onto the brake fitting. Clamp flare nut wrench end in a Vise Grip. Crank away. Most flare nut wrenches will open up when you put a lot of pressure on them. Craftsman are especially bad IMO. This is just basically using the Vise Grip to hold the flare nut wrench closed. Then you can put quite a bit more force on the end without it spreading open. I don't remember where I heard this, but it works! Jon Mortensen
A questions about the Rear Brake Swap.
My understanding is that the same calipers are used from 79-81. They are pretty easily recognizable. They have deep hats, like 3 inches deep. The caliper is huge also. The 82-83 calipers are much smaller, and the rotors have a much shallower hat. This is the one that uses the Maxima bracket. If you have the deep hats and the big caliper, then you cannot use the Maxima bracket. A company called ZQuip used to make a bracket. I have a set on my car right now. I used these because I was told that the smaller calipers are more prone to failure, specifically relating to the e brake mechanism. In my experience, this is true. I have seen at least 10 later style calipers frozen. Never have I seen the early style frozen. The downside to the early setup is that it has a smaller pad, and the calipers are very heavy. When I did mine some 5 years ago I was able to mount a 87 240SX e brake cable fairly easily, I took out the second bell crank in the ebrake system and it all works pretty well. Were I to do it over again (and I will) I am going to go with something that can handle a little more heat. I have cooked the pads to the point where they start breaking apart in chunks. I am thinking vented rotor, possibly like Terry Oxendale has done (no ebrake then). If you are street driving and autoxing the early setup like I have should work fine. Mine only has problems after a long day at the track. Jon Mortensen -
The Ground Control hats are shorter than the stock rubber hat by over an inch (at least on mine--I have the "roadrace" version". So you will drop the car an inch or an inch and a half just by eliminating the stock rubber hats. If you only want to go down 2 inches from stock, run the stock length struts. If you section the struts and then run the adjuster all the way at the top, you will have very little sag in the suspension and it will top out over bumps (this is more of a problem in the rear, since most of us seem to like a little rake). Topping out is bad, especially if you hit a big bump in the middle of a turn and you're near the limit of traction. I figured my heights on the perches this way: set the coilover so that at the top of the threaded adjuster the spring is touching the perch and the hat. I figured that would be as close to stock height as I could get. That turned out to be a bit high in the front with the adjusters all the way up. I wanted to go DOWN but with so much adjustment you should be able to find a happy place in there somewhere. Good luck, Jon Mortensen -
Do you know what kind of flares are on the green Z on your website? Are those MSA's IMSA flares? Seems to me the problem there is that they look a little less finished when they are not glassed into the body. Jon Mortensen
I am running a 10 inch wide slick on an 8 inch rim because I have stock fenders. I would like to run these tires on a 10 inch rim with a different offset to make track width wider. I like the idea of the ZG because if I bash one up on a cone I can just buy a new one and bolt it on. How wide are those things. Some pics looks like 3 inches, some looks like 1.5. Thanks, Jon Mortensen
