JMortensen
    68
  1. There is another way to retain the axles, I've never seen it done in a Z, but I've seen it in Ford TTB front axles when installing aftermarket LSD's that don't have circlip grooves. You pull apart the slip yoke and put a spring in there, so that it is always pushing the 2 halves of the axles apart. There is still some room for compression, but the stub axles won't work themselves out. Works for F150's that are rockcrawling, should work for Z's. The trick would be finding a spring that is the right diameter. Jon
  2. I just put a long block in my '93 Toy 2wd. I am having a strange problem with the AFM. It is honking! Sounds like a very quiet car horn. It does this at idle, but then it seems to go away when the truck warms up or when RPMS get over about 2000 (no tach, so that's my best guess). The only previous experience I have messing with this AFM is about 10 years ago I opened it up and richened the mixture to go with a camshaft I had purchased. Other than that, its been doing its job with no complaints. I am not really fond of FI, and I don't really know much about it. Maybe if I was a little more FI friendly I'd learn something about it so I didn't have to ask questions... I also had a idle surging problem, to fix that I cleaned the throttle body and reset the TPS. That seems to have fixed the surge, but I still have no clue on the honking AFM. Any help appreciated. Jon
  3. A real Daytona wouldn't have 6 spoke ZX wheels on it... Jon
  4. I just thought of something. If your mechanic didn't use a "sleeve" to put the valve stem seals on he may have ripped them. This sleeve I'm referring to is like a drinking straw that is tapered at one end, and you just slide it over the valve spring retainer groove. If you don't use one, then the seal gets caught in the groove, and it is very easy to cut the seal. If you do a normal compression test, you can tell if you've got bad rings or bad valves. Just check the compression then squirt a little oil in the cylinder and do the check again. If the compression jumps up, then you've got bad rings. Jon
  5. If that's the stand up unit with wheels to roll around like a dolly then it is the quietest compressor I have ever heard. My buddy has had one for a few years now. I envy you both. Jon
  6. Mid 80's Civic or Integra blower fan bolts right into the early 240 Z just make 2 new wires, not sure about the later Z's. It gives more airflow, still not "blow your hair back" power. I read once about putting a GN (or Regal I suppose) blower in. Don't remember the specifics, I think it required more mods. That was really supposed to push the air around. I always equated the stock fan's power to having an 80 year old with emphyzema stuck under the dash breathing on you. Jon
  7. Check http://www.zhome.com in the technical articles there is some info. Jon
  8. Isn't that the usual MO of a bad module? Gets hot, won't work, cools off, works fine? Vapor lock could be caused by the heat too, I suppose... The engine would definitely have heat soaked while sitting in the parking lot, so don't count heat out yet. I've got a mechanical temp gauge on my Z, probe mounted in the thermostat housing and it will run at 190, turn it off it for 5 minutes, and the temp is at 210 or 215. Start it up, coolant circulates, and it immediately goes back down. Jon
  9. I agree with you BOZ, but I think it's worse than that. I think if you are under heavy braking there would be a tendency to twist the TC clevis bracket off the control arm as well, especially when braking hard on a rough road or track. I know there isn't a whole heck of a lot of movement in the TC rods, but there's got to be a pretty substantial force applied to the rod when braking and a vertical force from going over bumps simultaneously, especially on slicks. At least the stock unit relied on 2 bolts spreading the load over the top of the whole control arm, and had a bit of a damper in the TC and control arm bushings. I much prefer the design I have, which is much the same as the now defunct ZFR design. Only difference is mine uses 3/4" rod end and turnbuckle. All that said, I haven't heard anyone complaining of broken AZZC control arms. Yet. Jon
  10. You can cut the race with a dremel tool either with a cutoff wheel, or if the opening is too small with a grinding burr. Once you cut it it will probably fall out on its own. Just try not to cut into the flywheel. A little scratch won't hurt, but don't put a huge notch in the flywheel. Jon
  11. JMortensen
    lsd?
    The finned cover will fit any R200, but they stick out about 3 inches off the back of the diff, so you would need to make a new mustache bar (still called that in 280ZX right???) to fit. Stock unit won't even be close. Jon
  12. If the car isn't going to be ultra stiff and low, I'd go for the rear sway bar. Even on street tires when you are at a reasonable height and spring rate, the car will still lean quite a bit under hard cornering. For the rear if you're just looking for a sporty ride, go poly on control arms and mustache bar. With the coilovers you mentioned and some good struts, there's not much more to do, unless you want to start changing toe settings, at which point you can go with G Machine bushings or adjustable control arms. For street driving that's probably more trouble than its worth, unless you find that you've got one of John C's newly discovered faulty strut housings. Stock control arms put rear toe right at 0 if I remember correctly, which is where a lot of racers like it. Jon
  13. I think rags was asking if you had your manifold extrude honed, Cody. Extrude honing won't remove huge amounts of metal. You need to port the manifold with a die grinder, then extrude hone if you want the super polished effect. Jon
  14. I agree with John C, Motul 600 or I've also used ATE Super Blue. Jon
  15. I have taken my Arizona Z Car flywheel to 3 machinists now. Every one of them said "WOW! Do you have a scattershield?" No kidding. The same with all 3. It is THIN. The last one told me to use this dye on it. I can't remember the name of the stuff (chem-dye???), but I'm sure someone here will know what it is. Anyway, you put the dye on the metal surface, let it sit for so long, then clean it all off. Then you spray this white foam on the metal, and wherever there is a crack, the dye will wick out and you can see it. The flywheel passed the test, so I stuck it back in. I also made some small 1/4" plate guards that cover the driver's and passenger's feet. I talked to a long time drag racer, and he said that a kevlar tranny blanket would work to control the flywheel. I called Summit and they said no, so I don't know what to think. Certainly it wouldn't hurt. There has to be a good option for those of us who still use Nissan trannies. Anyone else have a good idea, or an opinion on the kevlar blanket??? Jon
  16. I adapted the Mikuni linkage to my Cannon manifold and had a set of 3/4" velocity stacks made because the 3" stacks won't fit inside the fender on the long manifold. Jon
  17. You can measure the current draw with a voltmeter (on milliamps) as Moby said, then pull fuses one at a time. When you pull a fuse and the draw goes away, then you know which circuit is causing the draw. Then you just figure out what is on that circuit and where the problem is. FWIW, I hate trying to track stuff like that down. NEVER A FUN JOB I'm no electrical whiz either though... Jon
  18. Too late for that! Kitchak probably wishes he had that matress there at Sears Point a year or two ago when he DID flip it. Into a wall on the roof as I recall... Where has all the road racing gone? All I can find is NASCAR on Speed these days Jon
  19. I don't know if you can use stainless exhaust tubing or if you need something thicker. Closer to the bottom of the page... http://www.jcwhitney.com/catsubpic.jhtml;$sessionid$M3APMNIAABJQUQSNDV0SFE0CJUOXKIV0?CATID=3170&BQ=jcw2 Jon
  20. This one looks pretty close... http://www.pegasusautoracing.com/pdfs/025.pdf Jon
  21. I want one that says Practice random acts of getting the f*&!@ off my @$$! Jon
  22. My understanding is that the top half of the spring is sprung weight, and the bottom is unsprung weight. You would want the tighter coils of a progressive spring to be at the top to increase the sprung and decrease the unsprung. This makes such a small difference that you would never know, but that's the deal. Jon
  23. Why don't you just adjust it back? All you did was add adjustment. How you choose to align the car is up to you... Jon
  24. Isn't Magnaflow made by Dynomax??? Jon
