5
Everything posted by Twisted46
Hey guys, when I installed my JTR V8 setup last year there was about a 2 inch void between the mount on the T5 and the cross member. That was using the JTR suggested GM P/N. I fabbed up what was basically a bolt extension to make it work but I don't trust it for long term racing. I have been looking at some OTS options but they are all for the later 2 bolt style mount and not the 1 bolt style the cross member was made for. Does anyone know of an OTS spacer that would eliminate this gap? I can always go custom but I am trying to save as much of my time as possible.
Your going to regret doing poly mounts at both locations, I have "cheap" rubber mounts on my JTR swapped race car. The transmission and motor mounting from JTR has been rock solid. I really think you need to follow the best instruction I've seen and read that book 3-5 times then get back in to things. This forum has been great to me with my swap when questions the book does not cover come up. Also I think everyone needs to understand that the JTR kit is only a starting point. You should not expect it to drop in and go. They give you a great canvas to paint on and that is why you paid hundreds and not thousands for that kit.
Front sway bar to strut
Twisted46 replied to manninen's topic in Brakes, Wheels, Suspension and Chassis
I think the idea is cool but I am not seeing what the benefit is? Simply to use a smaller bar? Reduced roll moment? Just for funsies? -
Underwhelming Lap Times
Twisted46 replied to Twisted46's topic in Brakes, Wheels, Suspension and Chassis
Hey guys, IIRC Greg Ira holds the S30 fastest lap at the same track nearly 20 seconds faster so yes they can be VERY fast. I have not had the car back to the track, full winter here in Ohio now. But if you read some of my posts I am pretty sure I found the major issues. Aside from braking much earlier than I should have my front tires were only using about the outside 1/4 in turns due to camber and probably some flex. I bought NCRAs and a triangular front brace. I also found a new tie rod end that was floppy that could have ended very bad. Have to wait until April to see results but I am expecting to cut 10 seconds with camber and braking. -
Well I may have found the true root cause today. I had the front in droop while changing oil and was playing with the drivers side wheel and noticed a huge amount of play. The new moog rod end is shot, couldn't tell with weight on the front. Thank god it did not let go at speed mid turn. -
Cary, in my opinion if you are worried about being criticized then you shouldn't be posting things on the internet so don't worry about it lol. I also know you have no way of knowing I raced BMWs for 7 years and only tracked the forester for the 2 years I was working on getting the Z together. That being said I am used to RWD sports cars and let me tell you getting a forester around a track takes a very special approach to handling, when your weight is 2+ feet off the ground you don't dare move the wheel mid corner, you purely steer with the pedals. Yes the Z required a lot more wheel work but I think I found my primary issue which is a front alignment that is all out of whack. Even the toe which I had set at a dealership is messed up (toe out at over 1 degree different each side.) Combine that with woeful camber and body roll and it makes sense why the car felt loose and was squealing tires at low speeds. I really think I will save 5 seconds when i get the alignment and body roll sorted. Another 5 when I start to brake later because I can carry more speed in the corners. Then another 5-10 as I learn the car more. I am going to counter your entry speed comment. If the car is already pushing in understeer more entry speed is going to slow your exit speed down. -
Oil Pressure Gage Not Reading Correctly With SBC
Twisted46 replied to Twisted46's topic in Gen I & II Chevy V8 Tech Board
Thanks Miles, I test this out when we get another nice day here in Ohio..... So next April 😝 -
I just got around to testing this. The gauge did not move at all. -
Negative Camber Roll Ceter Adjusters (NCRCA)
JHM, I am running 16X8s with 245 rubber at both ends, pretty mild. I will keep spacers in mind for the rear. JMortensen, I should know that.. duh, thanks for fixing my idiot brain. I am not terribly worried about additional wear as the car is trailered to the track and back home and two drivers with the local Z club each year. I was originally looking at normal bump steer spacers and figured why not get some more camber. I am also looking at Apex and T3 adjustable front end units. -
Thanks JHM, I figured I'd hear from you! That is the feedback I was looking for. I am 2" lower so every degree of camber I can get back is a plus. Also the track I frequent has a noticeable hump on turn 14 right on the apex. I never had a problem with it in my other cars but the S30 does not like it. I was wondering though if the increase of track width created more understeer without correcting the back. -
Hey guys, Looking for any feedback you might have on T3's NCRCA. I was already planing for bump steer spaces so it seems like these could be a beneficial upgrade to a lowered S30. I can find anybody reporting first had experience using them with results. https://technotoytuning.com/nissan/260z/negative-camber-roll-center-adjusters-240z-260z-and-280z
They make full sets of keyed lug nuts... I have a set on my car, not because I want them but because they had the right shank for my wheels. Unless you go to a machinist for some custom work, you are using off the shelf product that everyone has access to. Someone stealing wheels probably has a toolbox full of these keys... that they stole. I hate needing an extra tool just to get my wheels off but that is just my dumb opinion. My are is also parked in my garage in suburbia with 4 video cameras watching the house so that makes a difference in mindset I suppose.
Okay after spending more time staring the frame and suspension here is what I came up with for better/flatter cornering. Chassis work: I won't go in to detail in the this thread but my objective is to stiffen the car by connecting the front/rear frame rails to the rockers and tunnel, and tie the roll hoop to the front floor pan/rocker union. T3 triangulated strut brace. Camber: For now I am just going to stick with camber arms to get some use out of my new struts and springs. Body Roll: ST F/R sway bars (240z style) and bad dog plates. Misc: T/C Rod ball and socket swap. -
Thanks Miles, I'll try that. Car has been down waiting for me to change the water pump so I will give it a try this weekend. -
Here is some corner data, I recorded the chicane "kink" as one corner since you really never open the wheel up. Corner Forester 1 2 3 4 5 6 7 8 9 10 11 75.5 84.2 51 66 51 51.7 45.2 66.7 57.3 69.3 56.5 Entry 66.1 67.4 29.3 50 47.5 49 57.4 69.7 51.1 - 23.1 Mid 77.2 61.1 55.9 43.2 37.3 45.7 66.7 57.3 46 - - Exit 260Z 73.7 76.8 46.3 53.4 47.7 51.6 45.6 57.3 55 74 54.4 Entry 65.1 62 37 41.7 37.4 50.2 51.2 61 44.4 66.3 25.1 Mid 62.8 56.7 31 40.5 43 45.1 57.3 55 46.1 56.9 35.4 Exit -
Thank you JM, I will avoid the bushings completely then. My only concern with the plates is that the ones I have seen replace the top hats and lower the car significantly or are only for use with coilovers. I do not mind going plates but I am not planning on dropping $2K for coils for another year or 2. I am building the car slowly so I want parts that will work now and later. Is there a plate that can be used with OEM top hats? -
I tried a new sensor from ZCar, same problem. Maybe the gauge? -
Silverado, Duly noted and I will take you suggestions in to consideration that next time I out there. My driving line is not terribly different between the two but then they drive nothing alike and have to be treated differently. I will post my corner entry, mid, and exit speeds later today, that will tell a lot too. What do you guys suggest for front camber adjustment: arms or bushings? I would do the plates but my long term plans for the car involve a nice adjustable coilover setup So i will deal with that then. I plan to do bump steer spacers and TC rod pivot joints at he same time. I am also looking at the 1-1/4" ST bars considering I am on 180lbs springs for next couple years. Do you guys know of any triangulated front braces that work with V8s? Or is my best bet the welder and McMaster? -
Ben, Thanks again for the suggestions. Unfortunately I showed up to the track with my only GoPro card full.... dummy. Here is a clip my wife took, It was lap 1 so not full out but you can see how much the car is leaned over. https://drive.google.com/open?id=1lHUmts9dnRvONSdJXeCmxB1UYCDN7UCe Here is a session I recorded in the forester last year https://drive.google.com/open?id=1_cOSLhnecTk7zxuCZ1SZRiydYeTxENpG -
I was having trouble getting a video that made sense of the Forester and 260z overlayed. After reviewing data and video it is clear I was being light on the throttle (which I kind of knew) and shifting too early (not in the power band). I am confident I can shave 4 seconds off of sector 3 if I stay in 4th and brake 350ft later lol, my corner exit speed is way better in the 260z. Looking at sector 4 gave me a lot more confidence in the car and reminded me that it is all about the idiot behind the wheel. Sector 4 goes from a hard flat 90 right to a very tricky blind uphill that you really need to sweep a 1 turn with no brakes. It is nice to be able to see where exactly I made mistakes and really I was just being too timid with my speed. That being said I could see a ton of roll in external video, upgraded bars it is. Next season I will have more alignment capability so I am hoping to make my goal of getting in to the high 1:40s. Sector Trap Time 1 2 3 4 5 6 16.62 37.1 19.55 13.48 21.76 16.64 Forester 16.02 34.95 16.75 13.45 20.04 16.01 260Z 0.6 2.15 2.8 0.03 1.72 0.63 delta Sector Trap Speed 81 109 46 60 53 70 77 113 38 65 59 77 -4 4 -8 5 6 7 -
I looked at my lap data and have a different perspective. I'll try and post it later. Jesse, 1 - it is a decently fast track, my average speed is ~75MPH. The Scoob is a brick but the Datsun has lift. I am lowered 2 inches with an air dam and front lip that is 3 inches off the ground. 2 - Lap data tells the story, I was being a chicken on the back straight, off the gas and on the brakes 350ft earlier in the 260Z and not on the brakes as hard. I am running stock fronts with kevlar pads. Rear ZX disc setup. 3 - I guess the term is subjective. I don't mean drifting or anything close to it. I mean the front tucking in and rear swinging in to place nicely. JHM, no dyno runs yet but I have high output gm iron heads and a mildly aggressive cam. FWIW I will look in to a bigger front bar, the choice for no rear bar is because I don't have an LSD... Yet I just have to decide what camber method to go with. Track is the same surface 11 mos apart. JMortensen, Thank you Ben, Yes both times are running the chicane "link" Stock geometry with poly bushings and a lowering spring/strut combo. Yes it is not a racecar... Yet, I am working on getting it to that point but slowly over time. Thanks guys -
Well the catchy click bait title should be "My MONSTER V8 260z is SLOWER Than a Forester" The real story is that I got to put in some good laps at Mid Ohio this weekend and my best lap was 11 seconds off my best lap I set in my 2012 forester XT, 2:06 to 1:55. Now the forester had 2015 STI struts/springs and upgraded end links. It was also a stage 2 car so about ~300WHP but otherwise a stock car. I was running on 225 Hankook V12 EVO2s and had that thing at its absolute limit UNDERSTEER!!!!. Now the 260Z, a 2+2 weighs at least 500 lbs less than the forester, probably more but I want to scale it before making any claims. It is completely stripped with a half cage right now. The SBC is probably making about the same power. I am on KYB struts and German 280Z springs, I replaced nearly every bushing with poly stuff and new tie rods/ball joints. Stock front bar with upgraded links and no rear bar (stock R200). The SBC V8 is in the JTR position(just enough room to rotate the distributor.) It goes without saying the CG of the 260 is WAY lower than the Forester. 245 R888r 200 race tires. I had the tires singing really nice and the car FELT great, just a little tail end slide in each corner and I could put it exactly where I wanted. I had a ton of fun but was getting passed all day (part of running with Porche club lol.) I could care less about getting passed by $100K+ 911s or anything for that matter but I know that I should be faster than myself in a damn crossover. So here is the part makes me think something is up with my suspension geometry, I am making wider, stickier tires sing on a car that weighs less but I am going slower? Is there something that I am missing with my setup? My winter plans include more cage work, front and rear tower bars, and adjustable front camber. Anything else I should add to my list? I have a baby on the way so no AZC stuff lol. Note: of course I realize that the driver makes the single biggest difference in lap times and an AWD Subaru is a lot easier to drive at the limit. That is why I did not time my first few outings in this car until I really go to know it and get more comfortable.
Help needed on rear disk brakes
Twisted46 replied to 280zilla's topic in Brakes, Wheels, Suspension and Chassis
I had to shim about 5mm to center mine -
Alignment Suggestions For Track Day Car
Thanks a lot for the input guys
