59
Everything posted by A to Z
Interesting. Is that a VW dash?
1-4-2022 UPDATE. First update of the new year. I had a few hours and it wasn't TOO cold, so I went out and tackled the driver's door latch. For me at least, there was no way to get it out without removing the door frame, so out it went! At that point I was able to see it, but the guy that said there is plenty of room, must have hands the size of an 8 year old girl, or was kidding, because it is a tight working space! I had to grab each rod (3 in total) with needle nose pliers and push HARD to get them to come off the latch! I put a piece of cardboard behind so as to not slip and dent the door from the inside. After I got them off, I found that the latch I have is not at all like the ones I bought.......it seems the ones on my car were either the older version or the newer.....at any rate, the one I bought went on. I was unable to get the factory plastic pieces to work, and so I resorted to using 2 layers of duct tape to keep the rods from coming out ot the holes. I thought the door handle one wouldn't need it, but yes it came out, so that will be a quick fix and I will duct tape it in place. Then I put the door frame back in. NOT EASY. But I got it all back together. Weird the window is now hard to roll down, but goes up easy and fine. The latch will be lubricated up before I put the inner panel back on, as well as the window rollers....maybe that is why they roll down hard. Any ideas? I then still had some time, so I went over them with the die grainder and decided to see how the JB Weld SteelStick worked in the small holes at the bottom of the right side (passenger) door bottom. Resuls are hit or miss, I also hit the area with some little bumps and I found holes! In the quarter right in front of the rear wheels! Look at the pics and you will see what I mean. Well, back to All-Metal filler. I also went ahead and ground the one big door ding on that door down to bare metal and covered it with glaze. Next time I come out, it will be cured and I can block it smooth. Lastly, I found when doing the door frames, a spot that was RUSTY....when I lifted the rubber flap over the door frames at the front, BINGO rust! Driver's (left) side was worse than the right hand side. I took both down to bare metal and sprayed both with rust converter. Later I will address these areas further. So, the louvers....ok, so I cleaned up the patch I made and the rubber trim fits right over.....so it is ready for sanding and paint. Thing about winter is it's not just the cold, but the days are shorter, so you can't get as much done....but every step froward is progress I suppose. Here are some pics.
Outstanding work!
12-26-2021 UPDATE: Ok, so following advice I got, I went ahead and used a steam iron and a wet towel over the rear deck carpet and dash carpet cover. I had to keep getting the towel wet for maximum steam effect. The wrinkles came out! I also went ahead and took the vise grips off the repaired area on the louvers...it worked! Thanks for the help guys. Here are some pics:
12-25-2021 UPDATE: Merry Christmas to all, and May the Lord Jesus Christ bless you all. I had a couple hours today, so I went to the garage, and prepped my rear spoiler, and then Wiped it down with Denatured Alcohol and sprayed it satin black. My masking worked real well....any overspray spots will come right off, as the clear is still to be sanded with 2000 grit paper and buffed. I painted the "Datsun" and "240Z" emblems, but the paint didn't adhere properly, so I will have to re-prep them once again, and give it another go! The pillar emblems just need the "z"' areas to be painted white (testers model paint??) I then took my louvers, which when I bought them had a crack...the seller DID tell me....I went ahead and lined up the crack, used the dremel to rough up both sides of the crack, and then cut 2 sheet metal pieces, dremeled them up nicely, and bonded the sheet metal pices to both sides of the crack with JB Weld, and used some vise grips to hold it together. I wiped the JB weld that came out so it will be easier to finish up later when I prep the louvers and paint them Semi Gloss black to match the rear spoiler. At any rate, here are some pics.
The streaks under the bumper are from me spraying the dusty bumper to wipe it off! Like I said, still needs more detailing and work. Thanks guys. Its a lot of work.....things are rusted on, don't want to come off, and so sometimes you have to bend, cut, etc to get it off, clean it up and then get it back on.....and thigns no longer line up.....for the pics it LOOKS like easy peasy 1-2 hours, but it was NOT. On a 49 year old car.....every time you work on a new area, you find old stuff that has to be replaced/fixed, even when it isn't a high mileage car. Now I will restore my factory asscessory louvers and re-insall. They will be semi-gloss black, just like the spoiler......these black pieces will match my rally stripe down the sides!
12/21/2021Update: I have most of the tail back together....still some more polishing to do and I need to paint the spoiler semi gloss black. The sides of the back bumper were HELL. The bolts on both sides were broken off from when I took it off, and the brackets were bent.....so I had to get inventive to get it mounted back on. The passenger side is the worst...again, because the gas tank is right in the way. Anyhow, still more to do on it, but so far doesn't look too bad.
ISOCYANATES! BAD BAD to breathe, this aserosol has it, read and heed
A to Z replied to A to Z's topic in Body Kits & Paint
they are the canisters......soemthing like OG/AV/P100 -
Thanks. Yeah, real scare. I purchased a 3M P100 respirator at Lowe's today. -
SPRAY MAX 2K Gloss Clear....****DO NOT USE THIS!!! IT HAS ISOCYANATES IT IN, IT IS VERY POISIOUS, IF YOU BREATHE IT, IT CAN KILL YOU. **** I used it today and it screwed me up a tad even just a hour maybe 2 with a mask on (dental mask). VERY bad stuff. Please read and heed. It is the same as some of the professional body work and paint stuff. Those guys wear respirators to protect them. A shade tree guy can try to use it like KRYLON and hurt themselves BAD. Please avoid this and stay away from paint with Isocyanates in it. Like I said, just a tad exposure and I can feel it.
12-12-2021 UPDATE: So I decided to go ahead and paint the tail and the hatch, and the roof portion from the hatch to the sunroof, and the back pillar sand almost half of the quarter panels. First I had to finish sanding out the bad spots. I got that done, and began sadning teh rest with my orbital sander adn 1000 grit paper. (It actually privides enough adhesion for paint, and the majority of the existing paint is just cleared over....I simply go over the spots that need it with the white, then clear) Then the process of clean, tape off, and prep and then I went ahead and shot it with my Expresspaint.com Aerosol cans in 904 Kilimanjaro White where needed. After that I put several coats of aerosol clear with catalyst hardener in it, called "Spray Max 2K High Gloss Finish Clear Coat Spray Paint". ( EDIT: DO NOT USE THIS!!! IT HAS ISOCYANATES IT IN, IT IS VERY POISIOUS, IF YOU BREATHE IT IT CAN KILL YOU. I will go back to the non catylist clear. It will shine just like this but must be 2000 grit sanded and buffed, which is no sweat. I breathed some of this stuff today with a dental mask on and it is BAD!!! It was enough I can feel it now...WHEW! Never Again! I went and read about it. ) Everything went pretty well, except for 3-4 spots near the gas door, where the paint didn't adhere properly and just ran. . I I started sanding it out to redo , but the sun went down, and the paint needed to harden a bit more before I could really get it ready to reshoot. I will give this paint 1.5 to 2 weeks, like I do on the rest to get hard before I even THINK of color sanding it with 2000 grit and polish it out. Even wearing a mask, it is tough on you. I really need to get out of there and quit breathing it. It's terribly bad for me. Here are some pics:
