christianmoller
    7
Everything posted by christianmoller
  1. As i'm half way in in this swap things that i post is mods that i already have done :). Another thing i did when i did the brakes was building new rear control arms, narrowed down track with with 16mm/5/8" to accommodate modified Rota wheels. That included shorter half shafts, narrowed in my lathe, they were hard so i have to buy some expensive inserts/tools. I also made a jigg to get angles correct when welding. They are now adjustable. I'm going polyurethane bushings as i want this to be a fast road car and not a track car only. With them i could go with the R180 for last summer to sort out the brakes. With the now mounted R200 i have to make new ones again🤣. /Christian
  2. Hello everyone, I was thinking of starting a thread about my LSA swap but i know there are several but if you are interested i'll post😀. I have a 260Z bought three years ago, drove it with the Inline 6 for two years. I started with the brakes as they were not so good so to speak..... I bought Porsche boxter S calipers from a 2016 and discs from a BMW F30 335i made new brackets and twin master cylinders. At first i made new hubs in aluminium but have now changed to hubs from a S13 as i had some flex that made my brakes a bit unpredictable 😱.
  3. Hello, I'm abut to get me a radiator as well, those measurements on the c7, are they with or without tank? It also looks that the condenser is included in most sales(a good thing). It's a -74 260 I'm in sweden so the range of radiators for a decent cost is limited and shipping and customs fees will eat some money..... Thanks Christian
  4. Are they compatible with GM lan? I have a GM performance harness for my LSA and it would be nice if they are. /Christian
  5. What is the size of gauges in 260/280? Are they 4-1/2" and 2-5/8? It seems like there is some sort of bracket kit on Speedhut webpage. Christian
  6. Hello all, Yet another one 1974 Z in a slow progress project. Gen 4 LSA with Lingenfelter heads, LS 9 cam, 2,4 upper pulley, 180 degree headers, homemade engine mounts and gearbox mount. T56 from a Corvette modified with bell housing, tail from a Camaro, mechanical speedometer, and Magnum mid plate with bigger bearings. Porsche boxster S calipers front and rear BMW f31 disc front rear,Twin master cylinder for balance, front hubs from Nissan S13, rear end from a ZXT and CVs(R200,4:11), Rear homemade control arms 16mm narrower (5/8), new half shafts to match control arms, Steering rack from a UK Vauxhall Corsa/Nova(power steering). Interior will see a cage(not fabricated yet), Cobra Nogaro seats with harness. Wheels are Rota RBs widened in rear to 9,5X17, front narrowed down to 7,5 x17 to get proper scrub radius, tires are Nankaang AR1 225x45-17 front and 255x40-17 rear. BC coil overs.
  7. hello, i think i found what i need. Thanks again Christian👍
  8. Super thanks I'll look in to that and see what i can find. Thanks again Christian
  9. Hello everyone, Can someone tell me wich AC compressor that is how to say "smallest" LSA or ZL1 camaro. I need room for headers and engine mount on right side in my 260z. I need the space behind the compressor for my engine mounts I'm using low mount alternator and Ac compressor. Thanks Christian Gothenburg Sweden
  10. LSA works, 5/8" to the hood and engine/driveline center as I6. A tight fit but it does work 😀 Have a nice evening Christian Gothenburg Sweden🍻
  11. Hello, Sorry for lifting an old thread.......... I just want to say thankyou for all the info in this thread, helped me a LOT 😀. Ignore the front wheels, I'm narrowing down fronts to get a proper scrub radius. Rear are 8.5x17 ET+4 (now ET24 9.1/4") front will be 7.3/4" ET24 when done with new hubs. /Christian Gothenburg Sweden
