Posts posted by ritrebor
Mine is through Hagerty for $30K which cost $367
There seems to be a big difference in quotes as mine is modified with a blown SBC, Roll Bar.
The only no no was running nitrous.
I told them the truth on everything I am running with pictures.
ritrebor
Sad news.
He will be missed.
ritrebor
I have been to their place in Torrance, and bought some parts from them.
They were mainly sending cars to japan.
Believe they supply Motorsport Auto with some of their repro fiber hoses and parts.
ritrebor
Got this from the Pinned FAQ.
"The Z31 got a different, stronger CV shaft. In addition to being stronger, the housing for the CV joint is smaller in diameter, and this means that it interferes with sway bar end links less. There are two different Z31 CV shafts. The normally aspirated Z31 uses a 6 bolt shaft. For whatever reason, these shafts are too long to be used in the S30 chassis. Don’t get NA Z31 shafts. The Z31 turbo shafts have 4 bolts, and they are the right size to fit into the S30, using companion flange adapters from www.modern-motorsports.com."
ritrebor
It's just a piece of chain that you bolt to the chassis and the engine to prevent the engine from pulling on the motor mount.
ritrebor
I have the 6 bolt evenly spaced companion flange adaptor from modern motors.
I have the 4 bolt 300zxt CV's that I want to install in my 280z with an R200
Are the companion flange adaptor's the same height so all I would have to redrill them to the 4 bolt.
If some one has a set of 4 bolt ones I would appreciate knowing the overall height.
thanks in advance.
ritrebor
I could, but I don't know if they are the correct height.
Anyone know how tall the 4 bolt ones are?
thanks in advance.
ritrebor
Looking for a 4 Bolt Companion Flange adaptor to convert to a CLSD in my 280z.
Already have the CLSD Diff and CV axles.
Just need the flange adaptors to finish
Looking for the 27 spline ones.
Have a MM 6 bolt adaptors to trade or buy.
ritrebor
Not sure, but some of the early 700r4 was not computer controlled like the later ones.
ritrebor
I might have one
Will look tomorrow
Also in Los Angeles
ritrebor
Believe #2 goes to the heater hose.
#3 is for a automatic transmission cooler.
Here is where your car was mentioned.
Johnc old car.
http://forums.hybridz.org/topic/122464-rusty-old-datsun-shell/
ritrebor
M10x1.25 x30M
ritrebor
240z and 280z hubs are different so the spacers will have different thickness.
ritrebor
Fuel Cell In Spare Tire location
in Fuel Delivery
Posted
It's a 16 gal cell with foam inside.
Sending unit works a for a chevy autometer guage.
ritrebor
