Posts posted by heavy85
Looks like you've been productive over the holidays! If I see that right the intake is rubbing the strut bar? If so it's probably going to at least rattle - I would fix it. Is your strut bar higher on the drivers side or is it just the pics?
Cameron
Yahoo!!! Its a rush ain't it!
Yeah - open headers in the garage. What a nice feeling ...
Burnouts will have to wait for it to get off the jackstands. Should not be too long.
Happy dance time
Started on the first try. The light at the end of the tunnel just got real bright so either I'm nearly dead or I'll be driving by spring and will make the first test and tune!
Cameron
OK I rewired my car and am scratching my head where fusible links go? Everything is fused already? You can't fuse the starter wire. The alternator wire (at least on the '02 donor Z28) goes straight to the battery. This leaves the one wire that goes from the battery to the fuse block? The Camaro harness has some fusible links in them as well as the large 'Maxifuses'. I'm only using the Maxifuses but am concerned I need the fusible links somewhere. Searching just confused me more so can someone please explain exactly which wire we're trying to protect - I assume it's the one up to the fuse block? This went all the way to the ignition switch and back on the Z28 which is I assume why there was the fusible links added as there are a lot of potential shorts along the way. Mine is about a foot long so I dont see the point. Any insight would be helpful.
Thanks
Cameron
That's a good point Cameron. I wish I had something to autox in for the last 5 years.
I had to break down and take the daily driver SVT Focus to the last race of the season to get a least a bit of a fix in for the year. A one front wheel wonder is no comparison to the full slick beast though ...
Not that what I say matters but I would keep it together and save up for the parts. No use tearing it apart just to let it sit waiting for funds. I know it's sucked having mine down the last year for the swap ... lost a whole race season. After all you are 'suffering' with a 12.0 car!
Cameron
So is there really any difference between the high speed vs the standard speed G router? N routers at ~$170 are just too much when I can get a basement G model for $35 - I can always upgrade later for that much difference!
Thanks
Cameron
Well this is sort of a 'tech' question but anyway seems to fit best here. I bought my wife a laptop for x-mas and am shopping for a wireless router. I am clueless. It's a Dell and has a N wireless card. We have cable modem which I have been told is only about up to G card speed. Went to Best Buy today and there were four basic options for the G card. What appears to be the brand name Linksys (or something close) which comes in the basic for $50 or the high speed for $70. There was a what appears to be the generic by Belkin which is only $35 then there was another brand I dont remember which is equivalent to the high speed Linksys for $45 but again looks very generic. Any recommendations? We also have a Circuit City but I have yet to look there. The laptop will be used for photo editing including uploading to host/photo labs and web surfing. Thanks ahead for any advice.
Thanks
Cameron
My assumption is the bar twists about it's center. If you mount the bar off of centerline at both ends then how can it twist? This has nothing to do with stiction or range of motion of the bearings it's a pure mechanical thing. The real effect depends on what part of the bar is bending to begin with. I'm assuming the longer portion that connects the two sides in a 'normal' bar is doing most of the bending. Since you are holding the ends of this portion relative to each other you are forcing the twist to occur in the bend of the bar or the shorter legs that go to the endlinks. There is effectively less bar that can freely twist and therefore leading to my thoughts that the rate would go up.
So the real question is when will this thing be on the road! If I get the PCM back I will start the LS1 up for the first time over Christmas.
Cameron
I am still trying to figure out what make mine different? Let me know if you see something? Car should be done in 2008. I need to post some updated pics soon too.
Your brake booster looks a little off - does that have anything to do with it....
Benetton anyone???
Cameron
I'm not running the starting circuit through the PCM so I think the bypass module would work fine but I was also under the impression that module was all you needed for start/fuel/ect. What I'm worried about is some derate or ??? that the computer will enforce since the sensors are not plugged in. Depending on the answer to this question I may take you up on that module.
Thanks
Cameron
I'm VERY close to being able to start the LS1 up for the first time and am contemplating what to do with the PCM. If I just use a VATS by-pass box can I start it up and run without issue ... well other than the check engine light is always on? Will it run in some sort of derated protection or enrichment or something? I guess what I'm getting at is do I really have to have the PCM flashed to get rid of rear o2 sensors, air pump, etc if I'm willing to live with the check engine light? Eventually I will probably have it flashed out but am still trying to figure out the best way to go there and want to get it running over Christmas break.
Thanks
Cameron
Gas pedal (I cut the end off and welded it to the end of the Datsun pedal to use the unmodified LS1 throttle cable), fuel tank and lines (I took the soft lines apart that connect to the tank and re-used the ends plus took the hard lines & tee near the fuel filter and cut, jointed, flared to re-use them), fuel tank mounting straps, gas tank filler neck (cut twice and extend and slides right into the Datsun fill neck), plastic brackets that hold the PCM and fuseblock, shifter boot, driveshaft (haven't had it shortened yet so I dont know how the aluminum shaft will work), OBD connector. That's all I can think of that I used.
Cameron
So, has anyone tried putting green bulbs in your Z to get a orange indicator/flash/blink?
Uh is it just me or is anyone else wondering how red+green=orange???
Cameron
What happened to the stock shell of a dash you were working on?
Cameron
I dont think my first Z ... way back in high school ... ever had working brake booster. It was REAL hard to push the brake pedal. Just disconnect and try. Ended up getting a ticket for being too lazy to completely stop at a stopsign due to this. It almost takes both feet on the pedal if there's a long light.
Cameron
Weld the RT mount into the car and forget about a crossmember between the LCA mounts. Just make sure the LCA mounts can handle some strong lateral loads.
I'm curious why you say linking the LCA mounts is not needed. Is it due to what Jon has done up top with the diagonals from the cage? The crossmember sure seems like a good way to distribute the LCA loads into the frame. Generally you want to connect the loads in straight lines where possible?
I have one from a '72 that's in great shape. PM with an offer if your interested. Shipping would be from 62521.
Cameron
I would want to tie the control arm mounts together directly some way for the most direct load path. It seems the tranny tunnel really weakens the center of the car and the factory crossmember does a decent job of tying the sides together. Maybe just cut out those tubes you added to the crossmember to take the weight out ... or just get another unmodded crossmember as they dont weigh that much. I didn't design the factory part but my oppinion is it serves three basic functions 1) hold the control arm on, 2) hold the front of the diff, 3) add strength to the frame to help handle loads from the control arms.
Cameron
where can I get one of those -4AN to -3AN fittings for the slave?
Your local industrial hose store. Even our small town has two of them. They are usually known as 37 degree JIC fittings in the industrial world instead of AN but they are the same.
Cameron
Master is a -3, the hose (at least the one that was recommended on this board and was very expensive from Summit and is too short) is -4. I had to get a -3 to -4 and a 90 deg swivel elbow. Now need to get out my hose stretcher as the hose it ~1" too short... oh and I forgot the depth of the flare is huge so the std -3 to -4 adapter is too short. OK so I'm probably not the best example to listen to as I'm in about $150 so far and I have nothing that will work. Sorry just a little frustrated as I thought I could take the advice of a post here and save some time ...
Cameron
Been down a year for the ls1 swap. Engine is back in and will be driving by spring '08 ... a year later than planned but the while I'm at it got to me. Was a fast autox'er / occassional driver before that.
Cameron
My wife doesn't like me posting that kind of info on the internet
That's the first thing I thought of ... not sure what that's says about me ...
That $600 respirator is there for a reason. Silicosis (spel?) is a serious thing and killed a lot of miners back in the day.
Cameron
Master disconnect switch question
in Ignition and Electrical
Posted
It seems everyone puts the master disconnect in the + cable. I'm used to off-highway equipment that puts the disconnect in the ground cable. Unless I am missing something the negative side would be the best place to put the disconnect. For example (and this has happened to me) a common thing on Z's is for the battery + to short out on the frame. Having a disconnect in the batt + cable would do nothing to stop the short. Breaking the ground would stop the short. Having the disconnect in the ground requires a double failure to still have a problem if you tried to use it. Are there rules or something driving everyone to put them in the + cable? I checked the NASA rules but it did not specify.
Thanks
Cameron
