More notes for myself here...
  												 														GT 48 Curved Vane Rotor														   Diameter: 12.88     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															GT 48 Curved Vane Rotor																										  GT 48 Curved Vane Rotor 																							  GT 48 Curved Vane Rotor Drawing 																							GT 48 Curved Vane Rotor Description  												Wilwood's GT 48 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest, vibration free performance at any speed. These rotors provide the highest cooling capacity and longest service life for extreme braking short tracks and road course competition.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for GT 48 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        GT Slotted																							N																							GT																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$224.93																							160-4564 																																		Call (805) 388-1188        GT Slotted																							Y																							GT																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$284.93																							160-4564-B 																																		Call (805) 388-1188        GT Slotted																							N																							GT																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$224.93																							160-4565 																																		Call (805) 388-1188        GT Slotted																							Y																							GT																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$284.93																							160-4565-B 																																		Call (805) 388-1188        HD 48 Curved Vane Rotor														   Diameter: 12.88     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															HD 48 Curved Vane Rotor																										  HD 48 Curved Vane Rotor 																							  HD 48 Curved Vane Rotor Drawing 																							HD 48 Curved Vane Rotor Description  												Wilwood's HD 48 Curved Vane Spec-37 rotors are are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Our HD Series preparation includes full detail machining and smooth pad contact faces without slots.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for HD 48 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        Plain Face																							N																							HD																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$209.93																							160-12784 																																		Call (805) 388-1188        Plain Face																							N																							HD																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$209.93																							160-12785 																																		Call (805) 388-1188        SRP Drilled Performance Rotor														   Diameter: 12.88     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															SRP Drilled Performance Rotor																										  SRP Drilled Performance Rotor 																							  SRP Drilled Performance Rotor Drawing 																							SRP Drilled Performance Rotor Description  												SRP Drilled Performance Rotors feature a specially engineered directional cross drill and face slot pattern that improve brake response and pad performance throughout the entire range of light to heavy braking. The venting and cleaning action of the holes and slots will reduce pad glaze and disperse gasses and heat generated during the pad to rotor interface. The holes and slots also inhibit irregular pad compound build-up on the rotor faces resulting in smoother engagement and improved pedal response in all conditions. The material removed also contributes to lower rotating and unsprung suspension weight.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for SRP Drilled Performance Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        SRP Drilled & Slotted																							N																							SRP-BLK																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$269.93																							160-7172-BK 																																		Call (805) 388-1188        SRP Drilled & Slotted																							N																							SRP-BLK																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$269.93																							160-7173-BK 																																		Call (805) 388-1188        GT 48 Curved Vane Rotor														   Diameter: 13.06     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															GT 48 Curved Vane Rotor																										  GT 48 Curved Vane Rotor 																							  GT 48 Curved Vane Rotor Drawing 																							GT 48 Curved Vane Rotor Description  												Wilwood's GT 48 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest, vibration free performance at any speed. These rotors provide the highest cooling capacity and longest service life for extreme braking short tracks and road course competition.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for GT 48 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        GT Slotted																							N																							GT																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$224.93																							160-8165 																																		Call (805) 388-1188        GT Slotted																							N																							GT																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$224.93																							160-8166 																																		Call (805) 388-1188        HD 48 Curved Vane Rotor														   Diameter: 13.06     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															HD 48 Curved Vane Rotor																										  HD 48 Curved Vane Rotor 																							  HD 48 Curved Vane Rotor Drawing 																							HD 48 Curved Vane Rotor Description  												Wilwood's HD 48 Curved Vane Spec-37 rotors are are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Our HD Series preparation includes full detail machining and smooth pad contact faces without slots.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for HD 48 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        Plain Face																							N																							HD																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$209.93																							160-12786 																																		Call (805) 388-1188        Plain Face																							N																							HD																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$209.93																							160-12787 																																		Call (805) 388-1188        SRP Drilled Performance Rotor														   Diameter: 13.06     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															SRP Drilled Performance Rotor																										  SRP Drilled Performance Rotor 																							  SRP Drilled Performance Rotor Drawing 																							SRP Drilled Performance Rotor Description  												SRP Drilled Performance Rotors feature a specially engineered directional cross drill and face slot pattern that improve brake response and pad performance throughout the entire range of light to heavy braking. The venting and cleaning action of the holes and slots will reduce pad glaze and disperse gasses and heat generated during the pad to rotor interface. The holes and slots also inhibit irregular pad compound build-up on the rotor faces resulting in smoother engagement and improved pedal response in all conditions. The material removed also contributes to lower rotating and unsprung suspension weight.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for SRP Drilled Performance Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        SRP Drilled & Slotted																							N																							SRP-BLK																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$269.93																							160-7798-BK 																																		Call (805) 388-1188        SRP Drilled & Slotted																							N																							SRP-BLK																							48 CV																							Spec-37 Iron																							8.25																							9.46																							$269.93																							160-7799-BK 																																		Call (805) 388-1188        GT 72 Curved Vane Rotor														   Diameter: 14     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															GT 72 Curved Vane Rotor																										  GT 72 Curved Vane Rotor 																							  GT 72 Curved Vane Rotor Drawing 																							GT 72 Curved Vane Rotor Description  												Wilwood's GT 72 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest braking available.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for GT 72 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        GT Slotted																							N																							GT																							72 CV																							Spec-37 Iron																							8.25																							10																							$284.93																							160-8398 																																		Call (805) 388-1188        GT Slotted																							N																							GT																							72 CV																							Spec-37 Iron																							8.25																							10																							$284.93																							160-8399 																																		Call (805) 388-1188        SRP Drilled Performance Rotor														   Diameter: 14     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															SRP Drilled Performance Rotor																										  SRP Drilled Performance Rotor 																							  SRP Drilled Performance Rotor Drawing 																							SRP Drilled Performance Rotor Description  												SRP Drilled Performance Rotors feature a specially engineered directional cross drill and face slot pattern that improve brake response and pad performance throughout the entire range of light to heavy braking. The venting and cleaning action of the holes and slots will reduce pad glaze and disperse gasses and heat generated during the pad to rotor interface. The holes and slots also inhibit irregular pad compound build-up on the rotor faces resulting in smoother engagement and improved pedal response in all conditions. The material removed also contributes to lower rotating and unsprung suspension weight.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for SRP Drilled Performance Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        SRP Drilled & Slotted																							N																							SRP-BLK																							72 CV																							Spec-37 Iron																							8.25																							10																							$329.93																							160-8396-BK 																																		Call (805) 388-1188        SRP Drilled & Slotted																							N																							SRP-BLK																							72 CV																							Spec-37 Iron																							8.25																							10																							$329.93																							160-8397-BK 																																		Call (805) 388-1188        GT 72 Curved Vane Rotor														   Diameter: 14.25     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															GT 72 Curved Vane Rotor																										  GT 72 Curved Vane Rotor 																							  GT 72 Curved Vane Rotor Drawing 																							GT 72 Curved Vane Rotor Description  												Wilwood's GT 72 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest braking available.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for GT 72 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        GT Slotted																							N																							GT																							72 CV																							Spec-37 Iron																							8.25																							10																							$291.54																							160-11315 																																		Call (805) 388-1188        GT Slotted																							N																							GT																							72 CV																							Spec-37 Iron																							8.25																							10																							$291.54																							160-11316 																																		Call (805) 388-1188        SRP Drilled Performance Rotor														   Diameter: 14.25     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															SRP Drilled Performance Rotor																										  SRP Drilled Performance Rotor 																							  SRP Drilled Performance Rotor Drawing 																							SRP Drilled Performance Rotor Description  												SRP Drilled Performance Rotors feature a specially engineered directional cross drill and face slot pattern that improve brake response and pad performance throughout the entire range of light to heavy braking. The venting and cleaning action of the holes and slots will reduce pad glaze and disperse gasses and heat generated during the pad to rotor interface. The holes and slots also inhibit irregular pad compound build-up on the rotor faces resulting in smoother engagement and improved pedal response in all conditions. The material removed also contributes to lower rotating and unsprung suspension weight.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for SRP Drilled Performance Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        SRP Drilled & Slotted																							N																							SRP-BLK																							72 CV																							Spec-37 Iron																							8.25																							10																							$359.04																							160-11313-BK 																																		Call (805) 388-1188        SRP Drilled & Slotted																							N																							SRP-BLK																							72 CV																							Spec-37 Iron																							8.25																							10																							$359.04																							160-11314-BK 																																		Call (805) 388-1188        GT 60 Curved Vane Rotor														   Diameter: 15     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															GT 60 Curved Vane Rotor																										  GT 60 Curved Vane Rotor 																							  GT 60 Curved Vane Rotor Drawing 																							GT 60 Curved Vane Rotor Description  												Wilwood's GT 60 Curved Vane Spec-37 rotors are manufactured from a proprietary iron alloy developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking, and wear. The formulation for this alloy is a derivative of technology and materials that were significant in the development of the extreme duty military spec rotors that are manufactured by Wilwood. Every Spec 37 rotor is precision machined to less than .001" run-out, flatness, and parallelism. Combined with our proven GT Series asymmetrical face slot pattern and individual dynamic balancing, you are assured the smoothest, vibration free performance at any speed. These rotors provide the highest cooling capacity and longest service life for extreme braking short tracks and road course competition.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for GT 60 Curved Vane Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        GT Slotted																							N																							GT																							60 CV																							Spec-37 Iron																							8.25																							10.67																							$308.94																							160-13470 																																		Call (805) 388-1188        GT Slotted																							N																							GT																							60 CV																							Spec-37 Iron																							8.25																							10.67																							$308.94																							160-13471 																																		Call (805) 388-1188        SRP Drilled Performance Rotor														   Diameter: 15     Width: 1.25    Rotor Bolt Circle(s):  12 x 8.75															SRP Drilled Performance Rotor																										  SRP Drilled Performance Rotor 																							  SRP Drilled Performance Rotor Drawing 																							SRP Drilled Performance Rotor Description  												SRP Drilled Performance Rotors feature a specially engineered directional cross drill and face slot pattern that improve brake response and pad performance throughout the entire range of light to heavy braking. The venting and cleaning action of the holes and slots will reduce pad glaze and disperse gasses and heat generated during the pad to rotor interface. The holes and slots also inhibit irregular pad compound build-up on the rotor faces resulting in smoother engagement and improved pedal response in all conditions. The material removed also contributes to lower rotating and unsprung suspension weight.  NOTE & CAUTIONS: Premium grade, Spec-37 Heavy Wall Castings 												 																								   Ordering Information for SRP Drilled Performance Rotor																																		 																							Info																							Rotor Style																							Bedded																							Rotor Type																							Vane Count																							Material																							Lug I.D.																							Far Side I.D.																							Price																							Part No 												More Info																							Purchase        SRP Drilled & Slotted																							N																							SRP-BLK																							60 CV																							Spec-37 Iron																							8.25																							10.67																							$368.94																							160-13472-BK 																																		Call (805) 388-1188        SRP Drilled & Slotted																							N																							SRP-BLK																							60 CV																							Spec-37 Iron																							8.25																							10.67																							$368.94																							160-13473-BK 																																		Call (805) 388-1188
