I’ve spent a great deal of time searching the forums in order to find out how to setup my suspension. I think I’m finally getting the picture, but I want to make sure I am understanding this correctly. First of all I think that when people say they are using ‘coilovers’, that’s not really what they mean. A suspension setup can only be said to be a true coilover when the body of the shock absorber is threaded and the adjustable spring perch sits on that. I think what people mean when they say they have ‘coilovers’, is an adjustable setup that replaces the lower spring perch with an adjustable one mounted on a threaded collar that is attached to the strut. It is still a strut suspension.
I assume that the way you get extra tire clearance when changing to a ‘coilover’ suspension is that a shorter spring is used which allows the lower spring perch to be set higher (without increasing the overall ride height), thus the lower spring perch can be placed above the height of the tire.
As far as sectioning the strut, this is only required if you lower the stock ride height more than a specific amount (greater than 2�??). If you section your struts, then you need strut cartridges that are designed for this shorter length.
Is my understanding correct?
