Search the Community
Showing results for tags 'disc brakes'.
The story of how it all began, including pictures of ugly prototypes and crude early versions... What it all amounted to is a simple, strong bolt in swap that utilizes factory control arms and r200 mustache bar and allows the use of 2015 mustang brakes, hubs, cv axle ends and differential. The pinion yoke is a 1350 u joint one off a 1993 f250, it can be found at Denny's drivetrain. The struts that work with this setup are modified 2004 srt4 neon struts with their tops changed to the datsun 3 bolt camber plates. Most people simply contact bc racing and have them supply the 280z coilovers and exchange the bottom sleaves with the 2004 srt4 neons ones. Other people just use the coilovers they have and weld on the coilover tabs I also developed, so struts that work are basically anything you want. The brakes are either 13 inch rear brakes off a 2015 mustang or 11.8 inch brakes off a 2014 mustang. Both are dirt cheap, and both have a built in parking brake. I'm constantly updating the design with every batch, but here is what one of the components for a tacked cradle looks like. Pictured here is version 6, and the cradle bolted to the differential is version 4 I believe. *** Here's a picture of what it all ended up being in the end.
- 282 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Hello! I'm new to the "Z-Community" but what I can say so far is that it's GREAT! The enthusiasm and support so far has been fantastic. I recently purchased 1974 260Z with 56,000 miles on it. The car sat, covered on a car-port for nearly 30 years. I have a four phase plan for the car. Phase 1: brakes and Suspension Phase 2: drive train Phase 3: Engine upgrade phase 4: Body and Paint. I look forward to sharing the build with the community and drawing on the experience that is available. I hope that as my project progresses I can "pay it forward" to those that follow. Bob_260
- 25 replies
- Rota
- disc brakes
- (and 7 more)
