Zfan1 Posted May 24, 2011 Share Posted May 24, 2011 Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted May 24, 2011 Share Posted May 24, 2011 We need some details on your purple turd. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted May 25, 2011 Author Share Posted May 25, 2011 I used to post on here along time ago as Zfan, maybe 10-12 yrs ago when the site first started up. Nothing special, just a 010/020 high nickel 350 block with a 400 forged crank, 6" rods and JE pistons, pump gas friendly 10.83 to 1 compression. Ported AFR 210 Eliminator heads, custom ground roller cam, ported Victor Jr. intake, Proform 750 dp carb. NOS big shot plate system, 180 shot. Transmission is a built 700r4 with Edge 9" racing converter, 3800 stall. Rear end is a 200 LSD out of a 89 model 300zxt with Modern Motorsports stub axles and hub/adapters. Coil overs, Mickey Thompson 255/60-15's. It's just a little 1971 Datsun 240Z that is street driven all over the Dallas/Ft.Worth area. Surprises a lot of cars on the streets and on track too. I am looking at a LSX or 2JZ swap next year, maybe even in an old Mustang Coupe if not my Z. Mike Quote Link to comment Share on other sites More sharing options...
leopard_125 Posted May 25, 2011 Share Posted May 25, 2011 That's what I'm talkin about, that thing hauls a$$. Nice work!!!!!!! Quote Link to comment Share on other sites More sharing options...
sq_creations Posted May 27, 2011 Share Posted May 27, 2011 Very nice time. Any pictures of you z? Quote Link to comment Share on other sites More sharing options...
rsicard Posted May 29, 2011 Share Posted May 29, 2011 I used to post on here along time ago as Zfan, maybe 10-12 yrs ago when the site first started up. Nothing special, just a 010/020 high nickel 350 block with a 400 forged crank, 6" rods and JE pistons, pump gas friendly 10.83 to 1 compression. Ported AFR 210 Eliminator heads, custom ground roller cam, ported Victor Jr. intake, Proform 750 dp carb. NOS big shot plate system, 180 shot. Transmission is a built 700r4 with Edge 9" racing converter, 3800 stall. Rear end is a 200 LSD out of a 89 model 300zxt with Modern Motorsports stub axles and hub/adapters. Coil overs, Mickey Thompson 255/60-15's. It's just a little 1971 Datsun 240Z that is street driven all over the Dallas/Ft.Worth area. Surprises a lot of cars on the streets and on track too. I am looking at a LSX or 2JZ swap next year, maybe even in an old Mustang Coupe if not my Z. Mike Your Z is as good as it can be as is. Not much to be gained with a LSx or 2JZ, just more headaches. What year did you purchase the Modern Motorsports stub axles. Did the same and they are REALLY BEEFY. Also using the same R200 CLSD with 3.7 ratio. Only improvement might be beefed up 4L60E with steering wheel paddle shifters versus the 700R4. Other than that newer AFR COMPETITION heads might be a little bit better. Your Z is really 90%+ optimized right now. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted May 31, 2011 Share Posted May 31, 2011 Mike, welcome back! Good to see you post after a loooong time. Hope you stick around and have a beer. Davy Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 31, 2011 Share Posted May 31, 2011 Love the name of the car. You sir are a genius! You should see my 'blue turd'... Did I mention you were a genius in choosing that name? Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted June 1, 2011 Share Posted June 1, 2011 Have seen you "around" Fort Worth, and it runs just as good in person Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 4, 2011 Author Share Posted June 4, 2011 Very nice time. Any pictures of you z? Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 4, 2011 Author Share Posted June 4, 2011 Just a few more Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 5, 2011 Author Share Posted June 5, 2011 Mike, welcome back! Good to see you post after a loooong time. Hope you stick around and have a beer. Davy Thanks Davy, Glad to see some of the Old Timers are still around. Did you ever build that Z? Mike Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 8, 2011 Share Posted June 8, 2011 Thanks Davy, Glad to see some of the Old Timers are still around. Did you ever build that Z? Mike HAHAHAHAHA! eh, dont ask. I am still working on it since my move to NC. I have some rust issues that I am dealing with. I have 95% of everything I need and more to finish the swap, but I am in rust repair mode right now. I seriously doubt I will ever buy a car with a rust issue ever again, even minor ones. The kids take up my time too, but that's OK and the way life is supposed to work so I am OK with that. Still, I want to complete the car so I can clean out my garage Again, it's good to have you back. Davy Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 8, 2011 Share Posted June 8, 2011 Could you resize those pictures? They are slowing down my computer, and it's no slouch. Quote Link to comment Share on other sites More sharing options...
gvincent Posted June 8, 2011 Share Posted June 8, 2011 Nice looking Z Curious as to what rims those are and the size, what size tire? and rubbing issues? No lowering springs, stock ride height? I could almost read the size from one of the pictures but not quite. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted June 9, 2011 Author Share Posted June 9, 2011 Nice looking Z Curious as to what rims those are and the size, what size tire? and rubbing issues? No lowering springs, stock ride height? I could almost read the size from one of the pictures but not quite. The car has coil overs with 10" springs 250 lbs, the tires in the rear are 255/60-15 Mickey Thompson's. The wheel wells are rolled by yours truly, rims are Konig Rewind 15X7, zero offset, nothing fancy! Quote Link to comment Share on other sites More sharing options...
