GOTHALOSISM Posted August 18, 2011 Share Posted August 18, 2011 My combo switch is bad,yes I have cleaned the connections. Is there a way to setup a toggle switch system with the relays to turn on the signals? I know I would need one for right, left, and hazzards. At least I got my horn button to work finally. Quote Link to comment Share on other sites More sharing options...
jhm Posted August 19, 2011 Share Posted August 19, 2011 Sure...why not. I would think a 3-position toggle would work -- you'd need the style that gives you two "ON" positions and one "OFF" position in the center. Something like this should work fine: http://www1.mscdirect.com/cgi/NNSRIT2?PMAKA=79483988&PMPXNO=24096938&cm_re=ItemDetail-_-ResultListing-_-SearchResults Should be able to use your existing wiring on the steering column (and existing relays) provided it's all in good shape. I doubt this setup would pass a state safety inspection, but that may not be an issue for your particular situation. Unless you use the hazards often, I wouldn't even bother messing with them (which would definitely fail state inspection). I can't remember the last time I used my hazard signal. Good luck and happy motoring! r/John Quote Link to comment Share on other sites More sharing options...
Oddjob Posted August 21, 2011 Share Posted August 21, 2011 (edited) No, this won't work at all, unless you are going to rewire much of the car. A simple DPDT center off switch dosn't have anything like the number of poles you would need, nor does it have any possibility of recreating the switching logic of the original. I took a quick look at the wiring diagram I have, and it would take something like 13 poles to recreate the switch (just for the turn signals), and probably more when you start to do the logic. For example, I set out to replace the emergency flasher switch, which you'd think could be a DPDT. It wasn't. Take a look at the eventual solution here for a preview of what you would have to do to "replace" that switch. Scroll down to posts 18, 19, and especially 20 (open the PDFs in 19 & 20). It took 15 connections worth of switching to do, and is much simpler than the combination switch. I don't want to discourage you, it can be done, but you will have to do some circuit design. It won't be a half-hour project. Edited August 21, 2011 by Oddjob Quote Link to comment Share on other sites More sharing options...
beermanpete Posted August 21, 2011 Share Posted August 21, 2011 I worked out a similar solution as OddJob but using relays and a simpler switch. I did not include the 4-way flasher. The wiring diagram for my solution is attached. This diagram is a complete re-wire for our race car so there is no heater, wipers, horn, etc. You could use only the parts for the turn-signals. The diodes are for isolating parts of the car circuitry from a tow vehicle. Simply omit them if not needed. The problem on the early models is the use of the same bulb for brake and turn-signal function. There is a separate switch contact for the left rear, right rear, and front. It is possible in the later models with separate turn-signal bulbs the switch is less complicated but I have not studied it. Large file, sorry. NEW WIRING DIAGRAM.bmp Quote Link to comment Share on other sites More sharing options...
jhm Posted August 21, 2011 Share Posted August 21, 2011 Sorry guys, but I'm confused. The wiring at the turn signal switch is a simple 3-prong plug. When the switch is in one position, it completes the circuit for the left signal; and in the other position, completes the circuit for the right signal....true? Why can't this functionality be replicated by replacing the turn signal stalk switch with a 3-way toggle switch? Wouldn't the rest of the wiring in the system remain "as-is"? (Again, this solution assumes that the problem lies solely within the switch, and that all of the system wiring is good and can be used as-is.) Again, my apologies if I'm over-simplifying the problem...electrical issues are my weakest area. r/John Quote Link to comment Share on other sites More sharing options...
cgsheen Posted August 21, 2011 Share Posted August 21, 2011 Sorry guys, but I'm confused. The wiring at the turn signal switch is a simple 3-prong plug. When the switch is in one position, it completes the circuit for the left signal; and in the other position, completes the circuit for the right signal....true? Why can't this functionality be replicated by replacing the turn signal stalk switch with a 3-way toggle switch? Wouldn't the rest of the wiring in the system remain "as-is"? (Again, this solution assumes that the problem lies solely within the switch, and that all of the system wiring is good and can be used as-is.) Again, my apologies if I'm over-simplifying the problem...electrical issues are my weakest area. r/John IF Skittle is talking about his '76 Z, I'm with you. The '74 - '76 Z's have a simple 3-wire switch (which I have taken apart on my 260 five times in the last 9 months, sigh...) and you don't need to fuss with the Hazard Switch at all. Each time I've repaired mine lately, I've contemplated tossing the original switch and finding a reliable replacement. The Turn Signal Switch on the '73 and earlier Z is much different... Quote Link to comment Share on other sites More sharing options...
Oddjob Posted August 22, 2011 Share Posted August 22, 2011 Sorry guys, but I'm confused. The wiring at the turn signal switch is a simple 3-prong plug. When the switch is in one position, it completes the circuit for the left signal; and in the other position, completes the circuit for the right signal....true? Why can't this functionality be replicated by replacing the turn signal stalk switch with a 3-way toggle switch? Wouldn't the rest of the wiring in the system remain "as-is"? (Again, this solution assumes that the problem lies solely within the switch, and that all of the system wiring is good and can be used as-is.) Again, my apologies if I'm over-simplifying the problem...electrical issues are my weakest area. r/John Umm... you haven't said what year your Z is. The switch has changed over time. My remarks above are specific to the early Z (mine is a '71). Sorry for jumping to the conclusion yours was, as well.... Quote Link to comment Share on other sites More sharing options...
Zzeal Posted August 22, 2011 Share Posted August 22, 2011 I'm using a "Ron Francis Wiring" toggle turn signal switch. Worked fine in an initial test, but I'll have to remember to switch it off after making a turn. It's a six terminal affair and they've got a wiring schematic for it on their site. Steve Quote Link to comment Share on other sites More sharing options...
jhm Posted August 22, 2011 Share Posted August 22, 2011 Sorry, my bad. My car is a '74, and my experience is primarily w/ the later year S30s. Thx for clearing up the confusion, cgsheen! Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted August 26, 2011 Author Share Posted August 26, 2011 Agreed sorry for the confusion mine is a 76 as well with just the 3 poles. Quote Link to comment Share on other sites More sharing options...
