NewZed Posted February 2, 2012 Share Posted February 2, 2012 Howdy. The crank bolt is 27 mm. I just went out and stuck a socket on the bolt to be sure. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 2, 2012 Share Posted February 2, 2012 (edited) Yes, crank bolt is 27mm. I used the O'Reilly harmonic balancer puller for V8s, with some timing cover bolts to thread into the hub center, and a large washer for the main screw to set in to keep the center threads from getting damaged. Works perfectly and no chance to hurt the damper or crank. Here's a picture of what I used, but it's not the exact part... Edited February 2, 2012 by SleeperZ Quote Link to comment Share on other sites More sharing options...
R0N Posted February 4, 2012 Share Posted February 4, 2012 (edited) Thanks guy's That helped. I also rented the harmonic balancer puller. It's amazing they let you rent it for free. Btw I had a hard time moving the bolt. It was in gear and the break was on but the crank kept on spinning but so was the rear wheel. Here's how I eventually got it out without using an impact gun. http://youtu.be/O_6SFBg7_dg Edited February 4, 2012 by R0N Quote Link to comment Share on other sites More sharing options...
Gollum Posted February 6, 2012 Share Posted February 6, 2012 Yea, I had to chock the wheels good and use a 4ft breaker bar + a 3 foot bar... No fun. The entire car was lurching up on the chocks pretty good and when the bolt let go I had to catch the car a bit to keep it from rolling more than the foot it did... Yay. Glad you got it taken care of. Quote Link to comment Share on other sites More sharing options...
