nissun1 Posted December 10, 2011 Share Posted December 10, 2011 Hey guys im looking as to find out how to lower my ride height on my 240z . I've used the megan coilover adapter and threaded them all the way down although the ride height isn't where i want it to be. Anyone who has done this setup let me in on some tips. Quote Link to comment Share on other sites More sharing options...
h4nsm0l3m4n Posted December 10, 2011 Share Posted December 10, 2011 If you installed correctly it should not be difficult. Thread the shock body up and down to raise and lower the ride height, thread the lower spring perch up and down to change the spring preload. Make sure to roll the car back and forth a bit, after each adjustment for the suspension to settle and allow you to take an accurate height measurement. This is all not particularly difficult but may be time consuming. It will take a few tries to get the ride height on each corner exactly where you want it. Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted December 11, 2011 Share Posted December 11, 2011 Megans don't go low. Quote Link to comment Share on other sites More sharing options...
ashintar Posted December 11, 2011 Share Posted December 11, 2011 Is it on the rear or on all 4 corners?. Also which kit.did you use? Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 11, 2011 Author Share Posted December 11, 2011 I have them on all 4 corners and i believe i used the same sleeve type of coilover kit as you did Ashintar. Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 11, 2011 Author Share Posted December 11, 2011 It was this kit. http://www.zccjdm.com/catalog.php/azcarbum/dt93255/pd2117800/240Z_MEGAN_SUSPENSION_TUBES__STRUT_PLATES_ Quote Link to comment Share on other sites More sharing options...
ashintar Posted December 11, 2011 Share Posted December 11, 2011 Not sure what the issue can be honestly. I know crazyocto used them to slam the hell out of his ride and mine is pretty low with room to go lower. Only thing I can think of maybe Megan sent you s14s which are taller? Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted December 11, 2011 Share Posted December 11, 2011 Maybe you are looking to get the car unrealistically low? Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 11, 2011 Author Share Posted December 11, 2011 On 12/11/2011 at 1:52 AM, ashintar said: Not sure what the issue can be honestly. I know crazyocto used them to slam the hell out of his ride and mine is pretty low with room to go lower. Only thing I can think of maybe Megan sent you s14s which are taller? Maybe that could be the issue..the thing is the coilover kit says it could be used for s13/s14? Quote Link to comment Share on other sites More sharing options...
ashintar Posted December 11, 2011 Share Posted December 11, 2011 On 12/11/2011 at 8:43 AM, nissun1 said: Maybe that could be the issue..the thing is the coilover kit says it could be used for s13/s14? That's why I was asking if the height issue was just rear end related. The front coilovers don't look like they vary much but the rears are much different. s13 s14 As you can see the cartridge is much longer. Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 12, 2011 Author Share Posted December 12, 2011 I took some pictures today to give you guys a better idea of what im looking at. The rear. (fully dropped) The front. (fully dropped) The last one is the rear fully dropped. This is what the cartridge looks like screwed all the way down. Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted December 12, 2011 Share Posted December 12, 2011 I'm inclined to think that either they DID send you S14 coils, or there was somehow a mistake in the installation, because even though Megan's aren't the lowest of the low, they SHOULD go much lower than that. Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 12, 2011 Author Share Posted December 12, 2011 Sigh im on the hunt again! Unless one of you guys have a hook up or a trade for some s13 megans? Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted December 12, 2011 Share Posted December 12, 2011 Is it just me, or is the last picture the coilover threaded all the way up? Quote Link to comment Share on other sites More sharing options...
ashintar Posted December 12, 2011 Share Posted December 12, 2011 All you really need is replacement cartridges for s13. Megan sells them $100 a piece and you Could prolly get the s14s sold on zilvia pretty easily. Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted December 12, 2011 Share Posted December 12, 2011 If you ordered them new from Megan, can't you just contact them and tell them you got the wrong ones? Quote Link to comment Share on other sites More sharing options...
johnc Posted December 12, 2011 Share Posted December 12, 2011 On 12/12/2011 at 2:24 PM, turboHLS30 said: Is it just me, or is the last picture the coilover threaded all the way up? Ageed. Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 12, 2011 Author Share Posted December 12, 2011 On 12/12/2011 at 5:44 PM, ashintar said: All you really need is replacement cartridges for s13. Megan sells them $100 a piece and you Could prolly get the s14s sold on zilvia pretty easily. Do you have a picture of what your rear looks like? How much does the threaded cartridge stick out when screwed in? Quote Link to comment Share on other sites More sharing options...
nissun1 Posted December 12, 2011 Author Share Posted December 12, 2011 On 12/12/2011 at 2:24 PM, turboHLS30 said: Is it just me, or is the last picture the coilover threaded all the way up? Yesterday i went out and lowered each corner to see how far they would go in and thats as far as it went until it hit the end of the adapter tube. Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted December 12, 2011 Share Posted December 12, 2011 On 12/12/2011 at 6:40 PM, nissun1 said: Yesterday i went out and lowered each corner to see how far they would go in and thats as far as it went until it hit the end of the adapter tube. Maybe you're only threading that bottom one down. The top 2 have to come down more. Try some penetrating lube (WD40, PB Blaster, etc.) and see if it will go any farther. Quote Link to comment Share on other sites More sharing options...
