Perfect240z Posted December 31, 2011 Share Posted December 31, 2011 This is the cam from my L24, I was going to use this in my N42 head/F54 block, Its internally oiled so this cam is def from another motor. Anyone think I need a new one? What's that yellowing on it? Quote Link to comment Share on other sites More sharing options...
letitsnow Posted December 31, 2011 Share Posted December 31, 2011 Pictures are too out of focus to tell much, does your camera have a close up mode(macro, flower icon, etc)? Is that just baked on oil crap or is it rust? Quote Link to comment Share on other sites More sharing options...
Perfect240z Posted December 31, 2011 Author Share Posted December 31, 2011 Pictures are too out of focus to tell much, does your camera have a close up mode(macro, flower icon, etc)? Is that just baked on oil crap or is it rust? i'll take a new picture in a few minutes. Quote Link to comment Share on other sites More sharing options...
Perfect240z Posted December 31, 2011 Author Share Posted December 31, 2011 How are these? Quote Link to comment Share on other sites More sharing options...
letitsnow Posted December 31, 2011 Share Posted December 31, 2011 The wear on that one lobe does look kinda odd, but assuming it's just a clean spot and not galling, I'd run it. Quote Link to comment Share on other sites More sharing options...
Perfect240z Posted December 31, 2011 Author Share Posted December 31, 2011 The wear on that one lobe does look kinda odd, but assuming it's just a clean spot and not galling, I'd run it. I'll have to see what the cam number is, I don't know what L series it came from. I don't know if that matters when my rebuild happens. Quote Link to comment Share on other sites More sharing options...
Perfect240z Posted January 2, 2012 Author Share Posted January 2, 2012 I went to look at my cam the other day and I realized their isn't any oil on my cam...it has the holes on the lobes for the oil but not an external oil bar. I have a theory as to why my car wouldn't go passed 40mph and this may be why? A cam not having the smooth oily surface cant move correctly? Anyone want to chime in on my theory? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted January 2, 2012 Share Posted January 2, 2012 I went to look at my cam the other day and I realized their isn't any oil on my cam...it has the holes on the lobes for the oil but not an external oil bar. I have a theory as to why my car wouldn't go passed 40mph and this may be why? A cam not having the smooth oily surface cant move correctly? Anyone want to chime in on my theory? If your cam has holes in the lobes, it's for an internal oiling system, and that's what you have. The external system has no oil holes and the spraybar. Quote Link to comment Share on other sites More sharing options...
NewZed Posted January 2, 2012 Share Posted January 2, 2012 A dry cam wouldn't have any effect on slowing the engine down due to drag on the cam. The engine would just destroy the surface of the dry metal parts if it had run with no oil. Oil the cam up, put your fingers on it and feel the lobes for rough spots. Every lobe should feel nice and smooth. The yellow/brown material is just a buildup on the cam base that doesn't have any pressure on it in use, due to valve lash. If lash is set correctly, the base circle doesn't actually rub on anything. You can see that the lobes themselves are actually shiny from pushing on the rocker arms. That's the part that needs to be smooth and slick. Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 2, 2012 Share Posted January 2, 2012 (edited) The cam gear end looks to have two standard spring retainers, while the others appear to have anodized aluminum spring retainers. I can't see how they could be that light colored, with the front two (#1 Cyl) the typical 'dark steel' look of standards... I would look if the valves are the same in all cylinders, and then compare the weights of the retainers and even springs. Something went on with #1 by the looks of it to me! Edited January 2, 2012 by Tony D Quote Link to comment Share on other sites More sharing options...
Perfect240z Posted January 3, 2012 Author Share Posted January 3, 2012 The cam gear end looks to have two standard spring retainers, while the others appear to have anodized aluminum spring retainers. I can't see how they could be that light colored, with the front two (#1 Cyl) the typical 'dark steel' look of standards... I would look if the valves are the same in all cylinders, and then compare the weights of the retainers and even springs. Something went on with #1 by the looks of it to me! After looking at the cylinder head all this time I never realized the different color retainers, yeah I'll do that when I get to dismantling the rest of it. As for my cam I've been looking at web cams and I see they have a cam that can be used with stock to modified set up and the price is pretty good, I'll probably end up getting that when I do the rebuild. Quote Link to comment Share on other sites More sharing options...
