N42 INTAKE WITH JIM WOLF UPGRADE
J240ZTurbo
  On 2/2/2012 at 7:50 PM, J240ZTurbo said:
what about the weird stuff that goes under the airflowmeter with lots of vacumm lines connect to, does that also need to be plug?
I think most of that is idle air control, with input from the air conditioning. I ran a Z31 ECU for a while, and with a throttle body air bypass and a idle bypass, it idled fine. The only issue I had was I would stall sometimes when snapping off the throttle -- I was going to fix that with a dashpot, but never got around to it.
Wolf may be doing other things with all that weird stuff, so you should probably contact them to confirm, but I think you could bypass it without too much effect.
