macambra Posted February 6, 2012 Share Posted February 6, 2012 I bought a TPS from a S13 thinking it was a pot style and it's not- it's a switch style. What are you guys using for a TPS(make,model-if you don't mind)? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 6, 2012 Share Posted February 6, 2012 Haven't hooked it up yet, but I pulled one off a Hyundai, with pigtail. IIRC it's a 5k pot, the D fits the throttle shaft but it will require a custom mount to the TB. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted February 6, 2012 Share Posted February 6, 2012 Auto Z31s have the pot. You can tell by the seperate hanging harness off of them. Quote Link to comment Share on other sites More sharing options...
kaito Posted February 6, 2012 Share Posted February 6, 2012 The s13 TPS is actually both. The pigtail that hangs off of it is what you need to hook up. The red is 12v, white is your signal and black is obviously the ground. Make sure to ground it at pin 19 on the harness. I thought the same thing as well. I got mine from autozone for 30 bucks, from an automatic car. Quote Link to comment Share on other sites More sharing options...
FricFrac Posted February 7, 2012 Share Posted February 7, 2012 I bought a TPS from a S13 thinking it was a pot style and it's not- it's a switch style. What are you guys using for a TPS(make,model-if you don't mind)? There are two different TPS for the S13. One has just the pig tail from the standard and the auto has the pig tail and the plug just like the S30/130 TPS (as in switch). Don't use the plug built into the TPS if you have the automatic version as it is just a switch. Quote Link to comment Share on other sites More sharing options...
