sheet metal thickness?
ORANGEV8Z
I'm about to do a "second" restoration on my z. This time doing things I wanted to do before. I will be doing some cutting and welding on the firewall and the doors (deleting handles). What gauge sheet metal should I get to cover up all these holes? Can't wait to get it all torn apart and do it right this time.
18 may be overkill, 20 is easily bendable by hand to get the correct contours. Plus it's factory thickness.
On the other hand, 18 is thicker and will resist blow thru and warping. Granted it's not much help if you blow thru the sheet metal underneath.
Stay away from anything higher than 20, and there really isn't any need for anything lower than 18.
btw I used to be halloween z but after being away for a while after I logged in I couldn't do anything. Kept getting this...[#1000B] You are not allowed to visit this forum. I had to create a new account.
He's Back! Hide the silverware!
Welcome. :D
Edited by Trevor
