ZAMMM Posted April 19, 2012 Share Posted April 19, 2012 I recently purchased a new thermo time switch from MSA thinking it was the reason it would take my z 1 to 3 cranks to start sometimes. Since I have installed the new thermo switch it has improved a little but some times I will have to crank it twice or it will crank the first time but takes 3-4 seconds to fire. I have noticed it to start sooner in the morning and harder while after driving or when its hot out.I also have noticed since installing the switch if it takes 3 times to start it doesnt sound flooded or fart when it finally fires up. Any direction would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
stravi757 Posted April 19, 2012 Share Posted April 19, 2012 Start by reading this, it explains in detail how the stock efi works on your car, its very simple to understand. http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf Buying a new thermo time switch was a waste on money IMO. Its much more likely that your water temp sensor(located right next to the thermo time switch) is causing the problems you describe. Sensor could be bad or the connections are very dirty. start there. Quote Link to comment Share on other sites More sharing options...
calvin280zxt Posted April 20, 2012 Share Posted April 20, 2012 Might do this already but do you leave the key on for a second to build fuel psi before cranking Quote Link to comment Share on other sites More sharing options...
theghosttanker Posted April 22, 2012 Share Posted April 22, 2012 check the air gap for the reluctor pickup in the distributor.....too large a gap can make for harder starting Quote Link to comment Share on other sites More sharing options...
motomanmike Posted April 27, 2012 Share Posted April 27, 2012 I'm not sure if the injectors fire for one split second like they do on alot of cars on the Z's or not but I have had success at the shop with having people turn their key on for a second or two, rotate back, back on a second or two and then back and then try to start. It usually will prime the fuel system pretty good in that manner regardless of what kind of car it is. Just another free thing to try. Quote Link to comment Share on other sites More sharing options...
