heavy85 Posted November 10, 2013 Author Share Posted November 10, 2013 Ran an autox today with the droop limiters and new rear control arms. Nothing fell off so thats good. Seemed very smooth to apply power so definitely liked that. I drove like ass so its hard to say much else. I continue to struggle with the back end wanting to lead between turn in and mid corner going into slower corners. There are no corners like that a Dragon so its not an issue there but most tracks have a turn or two like that and Autox have plenty. No rear swaybar and plenty of rear toe in so not sure whats causing it. Quote Link to comment Share on other sites More sharing options...
Sideways Posted November 10, 2013 Share Posted November 10, 2013 I want to apologize ahead of time as I full admit this may very well indeed be a ignant thing to ask- and want to express that my intent is NOT to offend in any, way, shape, or form- But merely devise a possible solution based on what Ive seen "usually" cause that symptom for quite a few people Ive encountered.Is it possible youre over-driving the car on entry? I frequently tell people to slow down to go fast, and rarely do I mean just on the throttle. Its super easy to try and turn in as hard/as quick as you can- Especially on low speed turns where the cars tend to "respond" better and the amount of grip up front can let you do it. Is it possible that youre simply turning in too fast? If you have treid slowing down your inputs on the wheel, may I ask how your trail braking is? Unless I missed something major, the bulk of your set up I saw would lead me to believe you should have a pretty confident setup that tends towards under steer and should really give you a good amount of traction to hook up/shoot out of a corners exit.Thanks Quote Link to comment Share on other sites More sharing options...
heavy85 Posted November 10, 2013 Author Share Posted November 10, 2013 Sideways - could be (most likely) an influence but there's something in the set-up thats off and exagerating it. For years I struggled with the front end pushing on slow turns like I described (most certainly over drive was a contributor) but now Its moved to almost uncontrollable tail happiness. I agree that driver is a huge contributor but I've been doing this long enough in this car to want to keep optimizing the set-up in addition to keep learning the nut behind the wheel. More I think about it, first I remember this was after I added that last degree of caster. Forgot about that. Maybe I need to take some caster back out. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 10, 2013 Share Posted November 10, 2013 I had trouble keeping the as_ of my car under me early this season-first season with the V8. I tried softer shock setting, lower tire pressures in back, dropping the tail to give more camber, etc-nothing helped. Two things fixed it: 1) Hoosiers, 2) decreased the rate of pedal input to throttle plate movement. I have drive by wire, and my tuner reduced sensitivity from 100% (stock setting) to 35% (lowest setting). Settled car down a lot. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 10, 2013 Share Posted November 10, 2013 Before the throttle changes, if I gave the car the slightest throttle on the back half of a corner-instant spin-out. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 11, 2013 Share Posted November 11, 2013 Ran an autox today with the droop limiters and new rear control arms. Nothing fell off so thats good. Seemed very smooth to apply power so definitely liked that. I drove like ass so its hard to say much else. I continue to struggle with the back end wanting to lead between turn in and mid corner going into slower corners. There are no corners like that a Dragon so its not an issue there but most tracks have a turn or two like that and Autox have plenty. No rear swaybar and plenty of rear toe in so not sure whats causing it. I'd play with the shocks some, either down in the rear or up in the front. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 11, 2013 Share Posted November 11, 2013 Looking at your photo, how much camber front and rear? In the photo of the car in your driveway, the rear of the car looks kind of high. Can you lower ride height and add negative camber in the back? Quote Link to comment Share on other sites More sharing options...
heavy85 Posted November 12, 2013 Author Share Posted November 12, 2013 Looking at your photo, how much camber front and rear? In the photo of the car in your driveway, the rear of the car looks kind of high. Can you lower ride height and add negative camber in the back? Ha - If you are referencing my avatar pic ... thats many years ago when I first brought it home. Can independently adjust camber. Been this way with both Rivals and RS-3s at various camber settings. I'm still leaning towards too much caster. Its also off throttle. Maybe need to play with shocks which I tend to ignore. Quote Link to comment Share on other sites More sharing options...
heavy85 Posted March 2, 2014 Author Share Posted March 2, 2014 Its that time again already! March 22&23 just three weeks away. www.dragonhillclimb.com Car is almost ready but still need to decide on tires. I highly recommend this event if anyone is even remotely interested its well worth it. Beatiful country, awesome people, challenging road. Cant wait. Quote Link to comment Share on other sites More sharing options...
tube80z Posted March 3, 2014 Share Posted March 3, 2014 Its that time again already! March 22&23 just three weeks away. www.dragonhillclimb.com Car is almost ready but still need to decide on tires. I highly recommend this event if anyone is even remotely interested its well worth it. Beatiful country, awesome people, challenging road. Cant wait. Maybe someday. I would love to be able to do the left coast hills. Quote Link to comment Share on other sites More sharing options...
socorob Posted March 3, 2014 Share Posted March 3, 2014 What safety equipment is required for a street car to participate? Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted March 3, 2014 Share Posted March 3, 2014 What safety equipment is required for a street car to participate? I'm pretty interested, too. I would want a 5speed for that drive, but the Tail would have to be a great time. Is there a breakout time, or is a cage required for everyone who runs? Quote Link to comment Share on other sites More sharing options...
heavy85 Posted March 4, 2014 Author Share Posted March 4, 2014 You need rollbar, harness, fire extinguisher (hand held mounted in metal bracket), and full driver gear. You can run on novice license too which means pay the fee and you are in. Quote Link to comment Share on other sites More sharing options...
