clutch slave cylinder gone mystery trans
corey_49
The other day i was driving the car hard and out of no where the car revved up very fast but the car did not accelerate. I drop the gas pedal and slowly reapply the gas. Right as i get into the power the car does it again revved up but did not move any faster. When i get it home i look under the car and see the clutch slave cylinder is leaking fluid when i press the clutch.
1) Is the clutch slave cylinder my only problem or do i need a new clutch too?
2) How do i identify the 5 speed in the car to match the new clutch slave cylinder or is this a generic part
Thanks
You need to include make and model of the car plus any modifications done to the engine and drive train if you want members to respond in a meaningfull way.
Without more information it sounds like your clutch is slipping and you have a leaking slave cylinder. The usual fix is to replace the faulty parts if diagnosis so directs.
Thanks
After the early 240Z (adjustable rod) the slave cylinders are the same for the L engine transmissions. They might even be the same cylinder, but with a different rod for the early ones.
Looks like you have two problems, at least.
Edited by NewZed
