Technotoytuning coilovers
I was planning on purchasing coil overs and I emailed TechnoToytuning and they told me it was a direct bolt on. anyone have any experience with these or have any other recommendation for direct bolt on coil overs for a 73 240z.
thanks
https://technotoytuning.com/nissan/240z/rear-coilover-conversion-datsun-240z-260z-and-280z
https://technotoytuning.com/nissan/240z/front-coilover-conversion-datsun-240z-260z-and-280z
Edited by yessire
For what it's worth, my shop (s30 Solutions) offers a very similar kit at a lower cost, if bolt-in coilovers is something you're interested in.
I've done several conversion kits for members on here without any complaints at all.
Edited by cockerstar
  • 5 weeks later...
As far as the original question. The TTT Complete Coilovers are indeed bolt in, but they are just sectioned struts with Ground control style sleeves and springs. The fronts are very easy to install, if youve ever done a wheel bearing R&R, its little more work than that. , the rears are not as straightforward.The biggest issue is that the rears do not come loaded (i.e Bearings, stub axles, seals, etc) so i recommend trying to source some new bearings, inner seals, and some 280z Stub axles while youre at it. you will need a press too. One of the harbor freight bottle jack operated presses did the trick when we did that setup on my friends car.
  • 1 month later...
  On 10/15/2012 at 8:02 PM, gr8gatzby said:
I'm curious too, who's aren't adjustable? T3's or S30 solutions? BTW; cockerstar, where in WA are you located? Anyone heard on initial pricing from him yet? Anyone install some of his kits?
They both are, that's why I'm not understanding where he's coming from ...
Edited by Poundz9oh9
I believe the earlier post about " not ride height adjustable" refers to changing ride height independently from preload. Some coil overs can do this. I am not commenting on either of these products, just guessing that was the point.
