Ben's Z Posted September 16, 2012 Share Posted September 16, 2012 How thick will my cam tower shims be? Any other suggestions? How will this effect using my stock ECU because of the compression change? Quote Link to comment Share on other sites More sharing options...
rayaapp2 Posted September 16, 2012 Share Posted September 16, 2012 Adjustable Cam Gear and your problem is solved. Compression should not be an issue with any stock USA spec L series ECU. The only issue you may have is emissions, but Im not savvy with emissions regs in Tx. or if they have any. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted September 16, 2012 Share Posted September 16, 2012 I don't think that's enough to warrant fear. For a simple "hi-comp" mod people normally shave .08 off to get 10:1. So you'd be less than that. http://datsunzgarage.com/p90/ As for the shims, what does the machine shop say you should do? Normally they should know. Quote Link to comment Share on other sites More sharing options...
texis30O Posted September 16, 2012 Share Posted September 16, 2012 I tried getting you a head locally but could not find one through my resources. If you can call Doug and see what he has. I know that he is selling off a lot of his inventory. I have his numbers if you need them. ( work, cell, and his wife's number) Quote Link to comment Share on other sites More sharing options...
z-ya Posted September 16, 2012 Share Posted September 16, 2012 How thick will my cam tower shims be? Any other suggestions? How will this effect using my stock ECU because of the compression change? You can tower shims should be equal to what you shave. Less than 0.020 shave, I wouldn't worry about it. Derek (on this forum), can make you some shims. I wouldn't worry about the slight change in CR. Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted September 17, 2012 Author Share Posted September 17, 2012 Should have mentioned this is for a L28ET swap. Please take that into consideration on compression ratio Quote Link to comment Share on other sites More sharing options...
NewZed Posted September 17, 2012 Share Posted September 17, 2012 You could use this calculator - http://www.ozdat.com/ozdatonline/enginedesign/ - and reduce the head gasket thickness by .040" to simulate the shaved head. Quote Link to comment Share on other sites More sharing options...
Sam280Z Posted September 17, 2012 Share Posted September 17, 2012 You can have the head straightened before it is cut. When looking for someone to work a warped P90 a couple of years ago, I had a local shop claim they could straighten it and take less than 5 thousands off. I ended up using a different head that was already straight - but his option was there... Sam Quote Link to comment Share on other sites More sharing options...
