High End LS3 With Harrop ITB, T56 and R230 Build Log
  • Replies 58
rags, the best I could do was 143.8 at the half mile since I am on the rev limiter in 4th... I could not shift into 5th (I tried 3 times before giving up). I could have gotten 150 in the half if I had 5th gear... and maybe 185 in the mile. I am already getting a new trans from Jegs (I called Jegs, Hurst Driveline Conversions and Tremec), pulling my trans this Friday. I had no clue this was going to happen... The car shifts great at normal speeds in all 6 gears (car has 1340 miles on it) only 5th gear gave me a problem at the Texas Mile... 6th went in fine. I will be back in October to get my 185 mph run.
Zero, Nice find on youtube... Saved me the trouble... The guys that shot the video were great guys, They wanted to interview me at the staging grid but I declined because I really don't like to talk to a camera... little shy I guess.
harlest, I took a second 280Z crossmember and welded it to the back of the original one and to the frame (after cutting off the steering rack mounting bosses the engine mounts and cutting clearance holes for the lower control arm bolt). Then I sectioned the center to fit the width of the oil pan + an 1/2" clearance on both sides. I then put the engine in place and mocked up the engine mounts out of thin cardboard which I used as a pattern to fabricate motor mounts out of .125" steel sheet. Removed engine welded in new mounts. I will be taking out the T56 for replacement this Friday and I will get a couple of shots for you.
Never made it into 5th gear... Trans has a bad syncro??? Getting a new one from Jegs... I was taking it easy and made 143.8 (on rev limiter in 4th) well before the 1/2 mile 150 is very possible at the half mile. It would have done 185 in the mile and I will do it this October.
Rick, Enjoyed the short visit in Beeville last weekend.  Wow what a car! Nicest Z I've ever seen in person.  Like the poster said earlier, you have to see this car in person to get the full impact. Photos just don't do it justice. Most Z's that i've seen, there is always something missing or left undone but not this car.  You can look around it, over it, under it and every little detail has been attented to.  Can't wait until October to see what it will do with six good gears!
  • 1 month later...
Hey Rick I noticed you where running TTT rear LCA's on your Z. I have a set that i am going to install on my 280 this weekend. Did you use any of the "shims" TTT provided? im not quite sure how they are to be installed. From the other pictures ive seen I cant tell how many or where they are being used. Do you mind shooting a couple photos to better explain how you used them for your application? Thanks in advance
90% sure they go on either side of the strut tube housing, around the "spindle pin" or bolt that you used to replace it.  They're so you can space the wheel back if you want. Be careful how far you go though, because I'm running into issues with the tires kissing the flares. I moved mine back about an inch though.......
CrayZ, on 03 May 2013 - 06:38 AM, said:snapback.png
I will take some pictures this weekend for you... You need to put half of the spacers in front of the hub carrier and the outer half behind the hub carrier (if you want it in the stock location). if you want to shift the wheel forward or to the rear then put more shims on the opposite side of the hub, like 2 in the front and 6 in the rear and the wheel will move to the front of the car. In any case use all of the washer shims (think there are 8 per wheel, I will count them when I take the pictures) must be used.
CrayZ, I finally got under the car... Like I said previously to center the wheel just put an equal number of washers on each side. I want to add that I put a thin washer on the front side of the wheel carrier to take up all of the space between the heim joints since I did not want to stress them by bending them in slightly when the nuts on the shaft are tightened up.
FYI, if you compress the suspension with no spring in it, you can see where the shim really needs to be. It's not going to be as misaligned at full droop, but it gets worse as the suspension compresses, so checking it on the bumpstop is probably the way to go. I used bumpsteer spacers from a circle track kit to figure it out on my first attempt at adjustable control arms. I'm guessing TTT is sending out something similar.
So what your saying is that when the suspension is compressed without the spring on it, it will force the spindle to move to its "proper" location and I should "shim" to keep it in that spot?
On my arms I recall that what I did was to compress the suspension and check the position of the strut shaft in the camber plate hole. If it was forward, then I shimmed it back, etc. I was using 12mm strut shafts and 5/8" monoballs, so you could see if it was shifted forward or back.
Edited by JMortensen
Ok I get it. I will not have access to the strut alignment tools you used. When going back over it this weekend I will do my best to make sure it is aligned properly.
  • 4 weeks later...
  • 2 months later...
Rick,
Beautiful build.  I hope to do something similar.  Not busting balls, just curious that you bought the BullDawg LSX swap kit, but then fabricated your own mounts.  Can you give us any insight to this?  I've heard their mounts, John's cars and JTR's are good for the LSX swap.  I have heard that with these kits you may have to buy the 58m offset for the T56 trans to set it back close to the stock location of the original shifter.
Thanks for any insight.
Tyson
