CaptainJoe87 Posted November 19, 2012 Share Posted November 19, 2012 Ok, I have tried searching for this but I am not really finding the answers I am looking for. My money is limited and my car needs a couple things before I start putting too much money into the motor. I have a L28e that has been rebuilt about 20,000 miles ago. I have a set of 3-2-1 headers that I have yet to install because I am saving up for the exhaust pipe kit from thezstore.com and a cone air filter. Other than that my a/c compressor is removed because the pulley locked up and I have a N42 intake manifold that I am waiting to put on so I only have to change the gasket once. My question is about timing advance, I have read a lot of things on here about it but would like some more solid information on the effects of doing so. I read that if you advance the cam timing 4 degrees it will have a large impact. Would someone mind explaining the process of doing that as well as the types of effects it will have on the motor. I know through reading that advancing the timing alters the timing of the valves opening and closing which will increase engine compression. If I were to advance the cam timing 4 degrees as I have read on this forum, what type of differences will I notice over stock? Any change in the HP or Torque? Where in the RPMS will I notice the change? Is the difference noticeable enough to be worth doing the work? My main uses for the car is street driving, but I want to improve my skills and start doing autoX. The other type of timing advance I have read about is doing it from the distributor, which from my understanding is just loosening a screw and turning the cap. My questions with this method are the same as the cam adjustment. What effects can I expect from this method. If I advance the Cam timing, should I also advance from the distributor? I want to get the most safe output from this motor in its stock form while saving up to do some other things. Any Ideas for free/ cheap ways to improve the performance of the L28e motor would be greatly appreciated. I am pretty much trying to find some ways, with a stock EFI and mostly stock motor, to get the most out of this motor, power and response wise that I can. I have read a lot of other posts where people have been asking for cheap ways to get HP from these motors and it usually turns to turbo swap, which is why I wanted to ask about something a little more specific. My car needs a good bit more work before I start looking into a motor swap. I just want to keep improving this car as much as possible within my budget so I don't get too discouraged with my project. Thanks in advance for any information or help that you can give, be it a link to a thread I didn't find, or an answer to my question. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted November 20, 2012 Share Posted November 20, 2012 (edited) Your mods are limited by the stock efi. If you start changing things I would get a wideband to monitor AFRs. You won't see much improvement without getting more air/fuel through the engine. Have you read BRAAPs sticky? Edited November 20, 2012 by skirkland1980 Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted November 20, 2012 Share Posted November 20, 2012 I'm in for more info as well. I was going to swap my L28ET into my 77 over winter, but I decided against it to keep the car in E-stock for next autocross season. This means anything I can do to squeeze a bit of power of out the stock motor withouth spending too much money on anything that can't be used on the 83 L28et. A wide band is on my shopping list. Besides advancing ignition timing, I'm not too sure what my options are. skirkland, is BRAAP's sticky in a different forum, or is it no longer stickied? Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 20, 2012 Share Posted November 20, 2012 It's in the FAQs but easy to miss because it's in the "L Series" box at the top of the Powertrain page. Lots of other good stuff on the L series page. Here's a link to BRAAP's tips - http://forums.hybridz.org/index.php/topic/95316-braaps-l6-efi-induction-advice-and-tips/ Quote Link to comment Share on other sites More sharing options...
CaptainJoe87 Posted November 21, 2012 Author Share Posted November 21, 2012 Awesome, thanks. I'm going to read through that as soon as I have some time. Quote Link to comment Share on other sites More sharing options...
