List your Z's specs...
I got a PM from someone wondering how to get to the "Garage" (used to be called vbGarage).
Here's how to view stuff already in the Garage:
-Click on the word "HybridZ" on the far left of the dark (blue) bar under the top-left HybridZ logo. The dark blue bar has the following text spaced acrossed it:
"HybridZ v" "User CP" "Donate" "Search v" "Quick Links v" "New Posts v" "Logout"
(v is down arrow triangle)
Click on "Garage"
That takes you to the garage page. Unfortunately, there is no way to sort the entries.
If you want people to find your garage easily, put a link to your garage page in your signature (I did).
  • Replies 67
I dunno if this counts, since my Z isnt done, but heres what Im shooting for upon completion:
'72, 240 Fairlady Z.
Engine.
L28ET w. stock bottom end.
Volvo FMIC
1st Gen DSM BOV
MSnS
2.75 Downpipe (Fab or bought, dunno)
Copper Head Gasket. ARP studs
T3/T4 Hybrid
2.75-3in. Exhaust with some type of muffler.
Other crap as well!
Other Drivetrain.
r200 w. LSD
5 Speed
Decent clutch.
Suspension/Wheels.
Urethane/Poly bushings.
Reasonable sport type suspension setup (something not quite bone jarring, but stiff and responsive)
Not sure on wheels and tires yet, need to do more research.
Frame.
Subframe connectors.
Rear strut brace (will be fabbing myself)
Front strut brace (Fab or buy, dunno)
Body.
Home grown paint and primer job. Unsure of color.
Lotsa rust repair
ZG Flares
Mild body kit perhaps.
The car is a long way off, currently its torn down to a shell and Im slowling fixing it and preparing it for primer and re-assembly. It'd be nice to see the car on the road in 2 years.
This is taken from a local nissan site where my car was car of the month alittle while back. The car recently ran 12.08 @125mph on street tires and ate a spark plug wire before I got a chance to make a a clean run on slicks. I few tricks were added since this article, but is pretty close to the same except I have a new intake, ported head, and a custom cam from webcams. You can also check out my car in the last issue of SportZ Magazine
Specs and Mods:S_Rear%20Quarter.JPG http://www.lonewolfperformance.com/
Cylinder head mods
ARIZONA ZCAR - adjustable cam gear
CRANE CAMS - valve springs and retainers
FERREA - stock sized intake valve w/ 1mm oversized exhaust valves
WEB CAMSHAFTS - Custom ground turbo cam
HKS - 2mm head gasket
LONEWOLF PERFORMANCE - race ported and polished P90 head w/ ceramic coated combustion chambers
ARP - head studs
LONEWOLF PERFORMANCE - Powder coated valve cover
Engine mods-
LONEWOLF PERFORMANCE - raceprepped and polished connecting rods
ARP - main studs
ARP - rod bolts
ABSOLUTE AUTOMOTIVE - assembled shortblock
MSA - euro single groove crank pulley
Intake/exhaust
LONEWOLF PERFORMANCE - Header w/ ceramic coating (inside and out)
JAMES THAGARD - custom intake manifold
MASTER POWER - T70 compressor w/ P trim wheel and turbonetics .58 exhaust housing
TURBO XS - RFL blow-off valve
LONEWOLF PERFORMANCE - custom intercooler pipes with cold air intake and K&N filter
SPEARCO - 1080cfm intercooler (previously owned by Lisa Kubo)
LONEWOLF PERFORMANCE - 3" mandrel bent ceramic coated stainless downpipe w/ v- band connections.
DYNOMAX - 3" race bullit muffler
240sx throttle body
LOKAR - Stainless throttle cable
LONEWOLF PERFORMANCE - fuel rail
52pph fuel injectors
ACCUFAB - Adjustable fuel pressure regulator
Stainless fuel lines
GREDDY - Profec B boost controller
Transmission/ differential-
Borg Warner T-5
SUPERIOR FRICTION - custom clutch
ARIZONA ZCAR - Lightweight billet steel flywheel
SUMMIT RACING - Universal Driveshaft loop
300zx 3.7 LSD
Interior
VICTORIA BRITISH - Full dash cap
Swapped red interior to black interior
MSA - Replacement floor pans (due to rust)
Digital to Analog Gauge swap with 130mph Speedo
PROFORM - shift light
ISSPRO - EGT gauge and sender
AUTOMETER - Air/fuel ratio gauge,
AUTOMETER - 30psi boost gauge
VDO - 25psi boost gauge
INNOVATE - LM1 wideband/datalogger
SONY - tape deck with 10 disc changer in glovebox
PILOT - “D†shapped steering wheel
Exterior
Closin pearl blue IMRON 6000 paint applied by me (Bodyshop manager at MHC Kenworth by day, part owner of Lonewolf Performance by night)
Remote mount Engine oil cooler
MSA - Aero II body kit with F40 spoiler
M&H - drag radials on 6 spoke 14" rims for street fun
M&H - Slicks on Centerline 15x9" rims for 1/4 mile track use
YOKOHAMA - A550H tires in the front
Misc/Other
WALBRO - 255hp (high pressure) fuel pump
TCI - rollstop/linelock
SDS - EM4-6F engine management system with upgraded MSD coil packs
GRIFFIN - Aluminum Radiator
ZIRGO - 16" electric fan with adjustable thermostat
SPEARCO - methanol injection kit
NGK - spark plugs
ACCEL - 8mm spark plug wires
semi-metalic brake pads
Notes from James
The car ran 12.33 @ 112.86mph on 8-13-04 before the turbo (previously was T3/T4 hybrid), valvetrain/head mods, and manifold upgrades. It also Dynod 345hp and 353ftlbs. at the rear wheels on 19psi of boost. I had boost controller problems on the dyno and couldn’t go any higher at that time. I’m currently running 30psi of boost and have not re-run the car in the 1/4 or on the dyno. I’m aiming for 525-550 when I return to the dyno late this year w/ the current mods.
Future upgrades include a 2 step rev limiter from Perfect Launch, swapping out the Methanol injection kit to one with a progressive controller, and a possible direct port nitrous injection system running a 75-125hp shot.
Eventually the drivetrain will be transferred out of this street car and into the 240z full drag car that I’m currently building as well.
1977 280Z
I used a JTR kit.
1989 5.7 TPI out of an IROC Z28,set for 1990 computer with MAP sensor, motor is all stock, and in bad need of a rebuild. 100k+ unknown miles on it. Cylinder number 8 is low on compression.
Accell 24lb injectors,
TPI throttle body air foil
cold air intake
shorty headers
Dual 2.5 exhaust,
40 series Flowmasters
84 700R4 tranny with B&M shift kit
stock R180 single spin w/3.54 gears
Stock springs and struts
6 point chrome moly roll bar.
300ZX wheels and tires
In this condition the car has run 13.03 @ 102.5mph and gets about 22 miles to the gallon. I'm about to install a 92 tranny with TCI parts and a 9.5 lock up converter. I also have an R200 LSD out of a turbo car that I installed 3.90 gears. I have CV joint axles and plan to use the Modern Motorsports adapters. The suspension just needs to go in a hole some where. I'm not sure what springs or struts to put in, I figure anything will be an improvement. The motor will need some tlc before too long. I'm considering a 383 kit.
1973 datsun 240Z
377 sbc installed with jtr kit (previously scarab/hooker install)
engine/transmission
canfield aluminum heads - 2.055 intake/1.60 exhaust valves, 65 cc combustion chambers, 200cc intake runners
comp cams extreme energy mechanical roller xr280r, part# 12-771-8, 2500-6500 rpm, 242/248 @ .050, .570/.576 valve lift, 110 lsa
comp cams roller lifters, high-tech pushrods
comp cams springs, retainers, 10 degree locks, arp screw-in studs, canfield guideplates
silvolite keith black hyp. pistons - 0.30 over, 3.48 stroke, 4.155 bore
crane gold 1.5 roller rockers
arp stainless steel bolts throughout (engine kit plus head bolts, main studs, flexplate bolts, converter bolts, oil pump stud, etc.)
arp 12-point poly locks
summit stage 2 5.7 rods
chevy cast 350 crank (welded up and turned back down for the 400 block)
weiand team g intake manifold (2800-7200 rpm)
holley 3310 vaccuum secondary 750 cfm (silver finish) - the pics, however, show a holly 6708 650cfm double pumper
tci flexplate
cloyes hex-adjust true roller timing chain
clevite race bearings (tri-metal)
melling m55a high volume oil pump
milodon oil pan (with windage tray, oil baffles)
milodon timing cover
msd 8360 distributor
moroso ultra 40 race plugwires
march performance serpentine kit, performance ratio
autometer phantom gauges
bowtie overdrives stage 3 200-4r transmission
b&m holeshot 2400 converter
b&m pro stick shifter
s&s full length headers
3" dual exhaust with borla xr1 mufflers
jegs 15 gallon fuel cell
carter street/strip electric fuel pump
suspension/brakes/wheels
280 rear strut assemblies with suspension techniques 240 lowering springs
tokico hp strut cartridges
"bumpsteer" spacers
suspension techniques front 1 1/8" swaybar
currently no rear swaybar, but have 7/8" msa bar to install
stock brakes with stainless braided lines
3.90 r200 diff
modern motorsports 300zxt cv axle conversion
weld rodlites wheels
15x6 front with 26x7.5 mickey thompson sportsman fronts, 3.5" backspacing
15x8 rear with 26x10.5 mt sportsman pros, 4.5" backspacing
body
bmw titanium silver paint
front and rear euro bumpers
clear turn signal lenses
clear marker lenses in the front
kaminari front spoiler
legendary cars cowl induction hood (purchased through jc whitney)
upgrade plans
trickflow 215r heads - 2.08 intake/1.60 exhaust, 67cc combustion chambers, 215cc intake runners
holley double pumper
scat9000 377 crank for 6" rods
kb194 pistons for 6" rods
scat 6" rods
coilovers
5 lug conversion
17" wheels for street use
subframe connectors a la pete paraska
1977 280Z Coupe purchased in March of 1992 from the second owner with 101,000 miles on it. Car was original except for wheels, rear hatch louver, and a front spoiler.
It was white with a brown interior. I drove the car as purchased for 5 years and 50,000 miles and then started the long upgrade project. I have driven the car 18,000 miles since the drive train conversion and it now has 222,000 miles.
BODY: Removed the hatch louver. Added the Motorsport Auto Aero II 4-piece ground effects kit with a conventional hatch mount 1-piece spoiler. Added the Motorsport Auto Sentra window mount rear-view mirror kit. Tinted the windows and painted the car a 1997 Cadillac Eldorado Pearl Red with a white racing stripe. The grill has been chromed.
INTERIOR: Converted the interior to black and red Katzkin leather with a custom charcoal & red carpet. It has a leather headliner, sun visors, ‘A’ pillar covers, door panels, seats, strut tower covers, and face of the rear deck. The only vinyl fabric is in the spare tire well area where it has been padded and fully covered in black vinyl. The seats have a 290 style ‘Z’ embroidered in red just below the head rests. It has an original, uncracked dash with all the original gauges with the speedometer being driven by a CableX unit.. It also has an Autopower 4-point roll bar that has been coated in black bed-liner material. The ash tray has been chrome plated and the interior coated in bed liner material. The AC system has the stock evaporator, condenser & expansion valve with a special compressor and drier. Along with foamed body panels, new seals throughout, and sound deadening and absorbing material it is now good to 100 degrees outside.
SOUND SYSTEM: It is a full Alpine system. It consists of a CDA-9851 head unit that is MP3, Ipod & Sirius capable, a CHA-5634 MP3 capable 6-dsik CD changer, an MRV-F545 500 watt RMS 4-channel amplifier with a Rockford Fosgate 1 farad capacitor, SR-17LS 6 ½†component speakers in custom enclosures on the lower front door panels with 1†soft dome tweeters mounted in the ‘A’ pillars, SPS-1304 5 ¼†speakers mounted in the side panels where the original 4†speakers were mounted, and an SWR-1042 10†subwoofer in a custom, ported, enclosure behind the driver’s side rear fender well.
SUSPENSION: Stock sway bars, Nissan European specification springs, KYB gas struts, urethane bushings throughout and three point strut tower braces front and rear.
BRAKES: 1981 280ZX master cylinder, Willwood forged Superlite calipers on 12.2†vented rotors in the front, 240SX calipers on 11.4†300ZX solid rotors in the rear, and an adjustable proportioning valve.
DRIVETRAIN: The car is the prototype for the Johns Cars LS1 conversion kit. It has a 1998 Camaro LS1 with K&N intake, 1 ½†headers into 2 ½†collectors that continue through an ‘X’ pipe and true 2 ½†duals to a single Magnaflow muffler in the stock location in the rear. The transmission is a 1999 T56 with a Hurst billet shifter that is connected via a custom driveshaft and modified ‘torque tube†(in lieu of a transverse mount) to a 1987 turbo 300ZX 3.70:1 LSD R200. The halfshafts have Spice ‘Brute Force’ universals and it all rides on Center Line 16x7†Trident II wheels with Kumho 215/55-16 Ecsta Supra 712 tires. Cooling is accomplished with the original radiator recored to four rows and the Camaro dual electric fans & shroud.
  • 1 year later...
nothin yet, in resto, but planned, 1976 280z stock l28, dark grey with silver flakes.
240sx 60mm throttle body
head milled .80, shimmed cam towers
ported manifold, polished ports
2.5 in exhaust
f54 flattop pistons
no a/c
k&n intake
nismo steel head gasket
Engine:
355ci SBC
steel lightweight crank 3.48 stroke
6" H beam steel rods
Probe 11:1 pistons
Brodix -11 heads 230cc, 2.10/1.60
Ti retainers, manly valves
Schneider .670/.680 lift 254/260 @ .050 solid roller cam
Comp Cams roller lifters and Pro Magnum roller rockers
Stud Girdles
MLS head gaskets
Performer RPM intake
Demon 850 carb
Long Tube headers
Trans:
Tremec TKO600
Centerforce DF clutch
Diff:
R200 3.90:1 w/ OBX helical diff
Front Brakes:
13" lincoln aviator rotors w/ Cobra 2 piston calipers
Rear: Maxima rotors w/ ford taurus calipers
Chrysler 1 1/32 aluminum master w/ stock booster, crane reservior, and Chevy celebrity auxilary vacuum pump.
275/40/17 front
315/35/17 rear
