burner rims
What "spare" wheels are you guys using? Im curious what are common wheels that can be used for a burnouts, slicks, yada yada. Common sizes from vehicles that can be had for cheap and have worked well for you guys in the past.
Edited by CrayZ
I know people use 280zx wheels as spares.
I have a 280zx inflata-spare as my literal spare wheel to save weight. Ha.
I tried to fit my steelies from my 240sx but the hub opening was too small; I have alloy wheels on it now but i havent tried to put those on the z.
Oh I have done quite a bit of searching here and there on this subject so I think I can lend a hand.
I think the swastikas are 15x6.5? My set was 100$, very cheap, good offset.
If you have stock rear drums, you can run Toyota Supra/Celica rims at 14x6 they are very cheap only downfall is that they don't fit the fronts.
A lot of American Racing rims came in 4x4.5 with near zero offset.
I believe some old mustangs also had the 4x4.5, old mustang rallye rims are usually 15x7 or 8 steelies with near zero offset.
I check the local AE86 forums (usually 15 and under) and Drifting forums (usually 17 and up), it's where I find some pretty good deals, and some I kick myself for missing (2 watanabe's for 200, a set of eagles, advan oni's etc)
