ComicArtist Posted March 23, 2013 Share Posted March 23, 2013 Just learned this the hard way. Picked up a set of Toyota 4-runner calipers that were marked s12+8, and being under the impression that all these calipers required vented z31 rotors and machined hub spacers, I bought rotors and spacers. Went to put them together and the calipers ended up being for stock rotors. I always thought that the calipers marked s12 were for stock rotors, and the s12+8 and s12w calipers fit vented rotors, but apparently not! Just a heads up to you unsuspecting buyers. I haven't seen this in any writeups before, and now I'm either stuck with rotors and spacers I can't use or calipers I can't use. Quote Link to comment Share on other sites More sharing options...
johnc Posted March 23, 2013 Share Posted March 23, 2013 S12W is the only caliper of that family that fits vented rotors. Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted March 23, 2013 Author Share Posted March 23, 2013 I was under the impression that the S12+8 did as well. Oh well, guess I'll look around for some S12W calipers and get rid of these. Quote Link to comment Share on other sites More sharing options...
Miles Posted March 23, 2013 Share Posted March 23, 2013 Go here: 6th post from top: http://forums.hybridz.org/topic/39435-help-what-brake-options-are-available-for-s30-z-cars/ Quote Link to comment Share on other sites More sharing options...
Xnke Posted March 23, 2013 Share Posted March 23, 2013 I'm using 1987 S12+8 calipers on my vented rotors. Pre-1986 calipers are generally for solid rotors, post-1986 are generally vented rotors. They do overlap some in 1986. The S12+8 caliper can utilize the RX-7 pads if they are appropriately modified. Quote Link to comment Share on other sites More sharing options...
sdm9785 Posted January 27, 2014 Share Posted January 27, 2014 Xnke, will the RX-7 pads fit both the vented and non vented version of the S12+8? Quote Link to comment Share on other sites More sharing options...
Xnke Posted January 28, 2014 Share Posted January 28, 2014 Yes, they will. But you will need to weld the backing plate up and re-drill the slide pin holes. Quote Link to comment Share on other sites More sharing options...
socorob Posted January 28, 2014 Share Posted January 28, 2014 I used the s12w with 86 5 lug hubs, rotors and spacers. I think the 86 rotor is slightly thicker. hawk pads were too thick to use, I had to get regular pads from o'advancedzone so the caliper would fit over the rotor. Quote Link to comment Share on other sites More sharing options...
Luigymonster Posted February 3, 2014 Share Posted February 3, 2014 Where did you guys buy your spacers? Links ? Thanks In advance Quote Link to comment Share on other sites More sharing options...
Xnke Posted February 6, 2014 Share Posted February 6, 2014 I machined my own spacers. Took about an hour, but it is highly dependant on which hubs are on your car. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted February 9, 2014 Share Posted February 9, 2014 Yeah, it's in the sticky. Quote Link to comment Share on other sites More sharing options...
