brianZortiz Posted March 29, 2013 Share Posted March 29, 2013 (edited) Hello hybridz, I have a leaking oil seal in front pinion. I called my local diff shop and they said they don't like to work on z cars (s30 specifically) because the driveshaft might be seized up due to a straight shaft to diff where there is no movement on u joints. A small conversation lasting a minute or so, but he said he can replace my oil seal. He wants the diff out of the car in order to fix it. Question is it even possible for the u-joint on driveshaft to seize up on s30z? Edited March 29, 2013 by brianZortiz Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted March 30, 2013 Share Posted March 30, 2013 Huh? I would look into a different shop. The driveshaft on Z cars is just like any other car, slip yoke in the transmission, 2 u-joints. Don't know what he is talking about being seized up. Any reputable shop should be able to do a pinion seal, its not a diff specific job. I worked at a firestone a couple summers ago and the techs there did several pinion seals while I was there. Call around to some other shops -Will Quote Link to comment Share on other sites More sharing options...
brianZortiz Posted March 30, 2013 Author Share Posted March 30, 2013 Yah, I've had my differential serviced at same shop. I will take it somewhere else, but I've never heard of a ujoint seized in an s30z car. Thanks. Maybe he was loading a pile on me but said s30z are a headache with problems arising everywhere. The work done before was did out the car, work was good. Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted March 30, 2013 Share Posted March 30, 2013 If the U-joints were seized up, your driveshaft would probably end up coming out on its own before too long. Maybe he's just a Datsun hater lol -Will Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted March 30, 2013 Share Posted March 30, 2013 More than likely he just doesn't want to be held responsible for breaking anything old, but either way it should be cheaper for you if you take it out anyway. On top of that I would bring the driveshaft and have them service or replace the ujoints. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 30, 2013 Share Posted March 30, 2013 I have 7 used differentials on my shelf-none of the front seals have leaked. Might be just as easy for you to buy one of the used diffs advertised on the forum and just swap'em. Anybody know if you can remove and replace the seal with diff in car, or do you have to press out pinion? Quote Link to comment Share on other sites More sharing options...
johnc Posted March 30, 2013 Share Posted March 30, 2013 Call Unitrax: http://www.gounitrax.com/ Quote Link to comment Share on other sites More sharing options...
brianZortiz Posted March 30, 2013 Author Share Posted March 30, 2013 I invested to much on this r200 3.9 12mm bolt. Yah Blue, it is cheaper taking it off and have it serviced. Thanks, John. Quote Link to comment Share on other sites More sharing options...
EuroDat Posted March 30, 2013 Share Posted March 30, 2013 I would remove the diff and consider taking it to another diff shop. BTW I have never seen a tailshaft seize up that bad that you cant get it out. Something like that could happen if you left a car standing 20 years, but still unlikly. Quote Link to comment Share on other sites More sharing options...
