Handy Wilwood Brake Plumbing Product
Just found this extremely useful wilwood item while cruising their site looking for the "usual" proportioning valve.
http://wilwood.com/MasterCylinders/MasterCylinderProd.aspx?itemno=260-11179
If you're re-doing your entire brake system plumbing, this looks like an excellent starting point. It allows you to replace the stock front/rear prop block on the firewall (73 and later) and the front/rear distribution/warning light block below the master, AND it includes an integral adjustable rear prop valve!  And if that's not enough, it has an integral brake light switch!
I just went through all this last year. Very tempted to rip it out and do again with this simple do-it-all device.
Edited by z240
