Looking for L28
mistah mofro
Preferably L28 with square port and something I can just drop in. Don't need exhaust pr intake manifolds I have my own thanks!
Looking in SF Bay area
What exactly are you looking for an L-28 block or L-28 cylinder head with sq ports ? Either way i have rebuilt short blocks 87mm bore with all new hard ware etc. Cylinder heads name it i've rebuilt headddssss.
Edited by zentech
Yeah but I don't wanna go through the trouble of removing 2 engines and installing one not to mention getting a truck, bringing tools, etc too much of a hassle. Anyways let me know guys
O/K, this is what i have in my inventory. I have three L-28 rebuilt short blocks (1) F/54 block bored .020 with a polished crank installed with clevite bearings and dished pistons, new timing chain kit and gaskets, (2) F/54 block bored .040 with ITM pistons, polished crank and clevite bearings, (3) N-42 block bored .030 with polished crank, clevite bearings and Nylen dished pistons not yet installed made in Japan. The last two blocks can be completed within two days of order. With that said, i also have a very good used F/54 with flat top pistons i bought from a machine shop and can be a good candidate if you need a used block. I have four N/42 heads with different specs depending on what you want. One N-42 head set up for dished pistons and ported that will get you 9.5 to 1 i believe somewhere in there. Send me a p/m and i'll give you my address to come and see first hand. Later !
Silenced ...
