zxt dist wire position and colors
on the underside of the 83 zx turbo dizzy is the 4 wire plug for the computer.  one side has the bump so you can only insert the plug into the dizzy the one way.  my question is what is the colors of the wires in each position of the plug?  my plug is ok.  but the wires are toast and i can not tell what the original colors were from the old harness.
jimbo
  • 4 years later...
Looking at the bottom of the distributor with the socket at the top, there are four male spade connectors numbered 1) top left 2)top right 3) bottom left and 4)bottom right. There are  four wires to be connected to these spade connectors, 12V+, Ground, Trigger 1, and Trigger 2. Which wires are connected  to which pins
I`ll check cgsheen to see if he shows this connection. I noticed that a lot of pictures that were hosted by photobucket are no longer visable.
