itrjon Posted September 30, 2013 Share Posted September 30, 2013 So I have a 1971 240z. I recently installed the following: 1977 L28 engine Old fly wheel from my L24 New Clutch/disc/throw out bearing 1981 5sp transmission r200 rear diff New fluids. I am hesitant to start the lady up bc when I push the car back into the garage, it feels extremely heavy. Although I have not installed the clutch slave, the car seems like there is a lot of rolling resistance. Does anyone have an idea of what I may be doing wrong before I try to start the car? Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted September 30, 2013 Share Posted September 30, 2013 Sounds like another throwout bearing collar problem. You're not getting enough distance and the clutch is contacting the flywheel. What collar are you using? 240z? Quote Link to comment Share on other sites More sharing options...
NewZed Posted September 30, 2013 Share Posted September 30, 2013 when I push the car back into the garage, it feels extremely heavy. Although I have not installed the clutch slave, the car seems like there is a lot of rolling resistance. There's not enough here to even guess. You're just asking for a wild goose chase. The part about the clutch slave shows that you have very little idea of what might cause "rolling resistance". Be careful with any advice you choose to follow. You're set to waste a lot of time. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted October 25, 2013 Share Posted October 25, 2013 He's pushing the car into the garage. I seriously doubt the clutch is even part of the equation since you normally push a car in neutral. I would ask him if he turned the driveshaft by hand after sliding it into the transmission but before bolting it to the diff. Quote Link to comment Share on other sites More sharing options...
