richie2619 Posted March 5, 2014 Share Posted March 5, 2014 (edited) I've seen some pics on Google where people have cut the in-board end off their control arms and made them adjustable, using heim joints.The stock units seem very well built and the ones I saw looked pretty damn good.Anyone here done this? Edited March 8, 2014 by richie2619 Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 5, 2014 Share Posted March 5, 2014 Lots of people have done it. I had a guy do mine before I had a welder. Pretty easy. This thread may help: http://forums.hybridz.org/topic/54771-adjustable-control-arm-lca-lower-control-arm-faq/ Quote Link to comment Share on other sites More sharing options...
richie2619 Posted March 7, 2014 Author Share Posted March 7, 2014 Thank you brother! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 7, 2014 Share Posted March 7, 2014 No problem. The link doesn't seem to be working since the update, here is the current link: http://forums.hybridz.org/index.php?showtopic=54771 Quote Link to comment Share on other sites More sharing options...
slammed_s30 Posted March 8, 2014 Share Posted March 8, 2014 (edited) Here are mine I did. Make sure you build a jig to prevent any warping or unwanted movement, you need it to stay as square as it was from the factory. Edited March 8, 2014 by slammed_s30 Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 8, 2014 Share Posted March 8, 2014 Beautiful. Quote Link to comment Share on other sites More sharing options...
richie2619 Posted March 8, 2014 Author Share Posted March 8, 2014 That's a great looking piece. It looks like you unbolt the rod-end, make your necessary camber adjustment and lock it down with the jamb nut when you're done.. Correct? Quote Link to comment Share on other sites More sharing options...
tube80z Posted March 9, 2014 Share Posted March 9, 2014 On 3/8/2014 at 7:10 PM, richie2619 said: That's a great looking piece. It looks like you unbolt the rod-end, make your necessary camber adjustment and lock it down with the jamb nut when you're done.. Correct? With that design yes. But you can also use a slightly larger bushing that allows you to have left right threads in the same piece. Generally this isn't a good place to make camber adjustments at as you also change the toe settings a lot. Check out bung adjuster nuts at midwest control. https://www.midwestcontrol.com/series.php?id=194 Cary Quote Link to comment Share on other sites More sharing options...
richie2619 Posted March 9, 2014 Author Share Posted March 9, 2014 Ok, now I understand how tech toy tune rear control arms work. Thanks for the link. Quote Link to comment Share on other sites More sharing options...
