franky240z Posted April 5, 2014 Share Posted April 5, 2014 Has anyone used them? Seem to be good value.... http://www.ebay.co.uk/itm/for-Datsun-240Z-L24-H-beam-4340-Connecting-Rod-Conrod-Con-Rod-Rods-ARP-/141012734111?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20d503909f Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted April 6, 2014 Share Posted April 6, 2014 I am not familiar with these and can not comment on their quality. I have briefly looked into pricing on connecting rods to build an L28et with a local company to where I work. Pauter Machine ( http://pauter.com/parts/rods/infiniti-nissan/), quoted roughly $1300 which comes with ARP rod bolts. Quote Link to comment Share on other sites More sharing options...
Joeoski Posted April 6, 2014 Share Posted April 6, 2014 I always see people posting about connecting rods from ebay but never hear of any one using them.Check these out 140mm rods. http://www.ebay.com/itm/200944342855?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649Then there are these rods that look to have 3 wrist pin oil holes there 133mm. http://www.ebay.com/itm/400482650317?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Quote Link to comment Share on other sites More sharing options...
Gareth. J. Posted April 6, 2014 Share Posted April 6, 2014 I purchased 'spool' H beam con rods for my L28 from ebay in Australia. No issues with quality so far, rev to 7200 on track. The only problem I had was I didn't realise the con rods were for 'floating' pins, not press in as per the factory setup. I had to get some extra machining done to my pistons to be able to fit retainers for the floating pin. Quote Link to comment Share on other sites More sharing options...
franky240z Posted April 6, 2014 Author Share Posted April 6, 2014 I've heard a few good things, nothing bad to be fair. Quote Link to comment Share on other sites More sharing options...
zbloke Posted April 6, 2014 Share Posted April 6, 2014 I know someone who's brought a set of rods very similar to the ones in the first post. Had a look at them yesterday and they do appear to be well made and finished, no burrs or sharp edges anywhere and the bolts do have ARP and a part number on them too......non of this means that they'll stand up to hard use though so only time will tell Quote Link to comment Share on other sites More sharing options...
1vicissitude Posted April 6, 2014 Share Posted April 6, 2014 Used crankshaft depot ones in my miata, so have tons of others. I've seen them take over 400whp in a 1.8l 4 cylinder without issue. They are fairly well balanced too. Just make sure to get the measurements and double check they'll work. Sometimes the description in the title isn't 100% accurate. Quote Link to comment Share on other sites More sharing options...
josh817 Posted April 16, 2014 Share Posted April 16, 2014 The stock rods are already forged and adequate to my knowledge for any practical purposes with ARP bolts. That being said I don't know if even $300 is worth the risk. There is a lot of metallurgy/material science that goes into rods which can't be spotted from the surface. Though if you're really dying for H-beam rods I suppose you could try. As 1vicissitude said, check or ask for dimensions. big and small end diameters, rod length, big and small end widths. I have heard sometimes the widths are not correct and have slop on the crank journal. Good luck Quote Link to comment Share on other sites More sharing options...
