nissanthanh Posted January 16, 2015 Author Share Posted January 16, 2015 So i think i've decided on a single 3.5 to the vibrant 3.5in/out resonator http://www.amazon.com/Vibrant-17970-Stainless-Steel-Resonator/dp/B0038HRNZM/ref=sr_1_1?ie=UTF8&qid=1421381462&sr=8-1&keywords=17970+vibrant to dynomax 3.5 muffler http://www.amazon.com/gp/product/B00029J38Y/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER and whatever folded tip i can get from the muffler shop. I'm hoping 3.5 will fit well under the s30 though.... Hopefully that'll sound right. I like the sound of the dynomax. Quote Link to comment Share on other sites More sharing options...
nissanthanh Posted January 16, 2015 Author Share Posted January 16, 2015 Ah fudge... muffler guy can't bend 3.5. I might go dual to the dynomax x muffler to two dynomax 3 inch welded rounds. Quote Link to comment Share on other sites More sharing options...
nissanthanh Posted January 16, 2015 Author Share Posted January 16, 2015 On 1/15/2015 at 2:29 AM, thezguy said: Drone is almost inevitable with a dual system and no mufflers. However the note you get is just awesome. I have a true dual 3" system with an Xpipe and bullets at the very end (tips welded on the bullets) 3.5" would be tough to fit but it's possible. Your biggest issue will be wrapping it under the diff. hey zguy, that might be what I will end up with. Your set up, except I want to use a dynomax xmuffler to help with drone. What you think? And instead of bullets, going to use the welded rounds. Quote Link to comment Share on other sites More sharing options...
socorob Posted January 16, 2015 Share Posted January 16, 2015 You will probably have to cut, weld and round the diff mount to go dual if you haven't done it already. Quote Link to comment Share on other sites More sharing options...
alainburon Posted January 17, 2015 Share Posted January 17, 2015 On 1/15/2015 at 2:29 AM, thezguy said: Drone is almost inevitable with a dual system and no mufflers. However the note you get is just awesome. I have a true dual 3" system with an Xpipe and bullets at the very end (tips welded on the bullets) 3.5" would be tough to fit but it's possible. Your biggest issue will be wrapping it under the diff. Sounds and looks good man, now I know where to go when I need my exhaust done...lol Quote Link to comment Share on other sites More sharing options...
thezguy Posted January 18, 2015 Share Posted January 18, 2015 On 1/16/2015 at 9:49 PM, nissanthanh said: hey zguy, that might be what I will end up with. Your set up, except I want to use a dynomax xmuffler to help with drone. What you think? And instead of bullets, going to use the welded rounds. Not sure about either one of those muffler unfortunately. I can tell you though, any of the straight through mufflers are going to be very loud. Also they will sound really good. I think your best bet is true dual into an X and route it like mine. Take your measurements with the new fuel tank in there and see which mufflers you can fit. Quote Link to comment Share on other sites More sharing options...
thezguy Posted January 18, 2015 Share Posted January 18, 2015 (edited) On 1/17/2015 at 3:06 PM, alainburon said: Sounds and looks good man, now I know where to go when I need my exhaust done...lol Been hard at work man! That TIG welder changed my life LOL Edited January 18, 2015 by thezguy Quote Link to comment Share on other sites More sharing options...
texis30O Posted January 18, 2015 Share Posted January 18, 2015 I hate to say it i will most likely change out to dual 3.5 oval, to 3" hand made mufflers and heimholtz resonators. A similar set up to what i have on my dd. No rasp No drone Quote Link to comment Share on other sites More sharing options...
Phantom Posted January 19, 2015 Share Posted January 19, 2015 (edited) I'm running dual 2.5" exhausts through an X pipe but after the axle they both roll to the driver side where they exit though a single Magnaflow muffler that has dual 2.5" inlets and a single outlet. The car has a good sound at idle, does not drone, but really lets you know it's there when I open it up. There is a video in the Miscellaneous tech forum about ZLED lights with the engine running at idle. I thought a lot about running a Y pipe with a single exhaust but ground clearance became too much of an issue. You'll need to have at least a 3.5" single pipe to flow air the same as dual 2.5". Edited January 19, 2015 by Phantom Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted January 20, 2015 Share Posted January 20, 2015 I am running 3" dual exhaust thru a Dynoflow single muffler with dual 3 " chambers in and out. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted January 21, 2015 Share Posted January 21, 2015 I've had both dual 3" with an x and 3.5" to dual 3". Magnaflow 3" bullets right at the tips. Still pretty throaty, but not nearly as loud as if the mufflers were in the middle of the pipe. Quote Link to comment Share on other sites More sharing options...
