adrenaline child Posted April 30, 2015 Share Posted April 30, 2015 Hi everyone. I have a 1975 that I have been working on for quite a while, I bought the car mostly complete (partially torn apart but It came with most of the pieces). Anyways, something it didn't come with was the front signals. So I bought the oval led lights often seen on semi's / trailers to use as front signals. The wiring for the original signals was all there so i wired the LED lights to the original wiring. I have the Hazard light working no problem, but when I turn the signals on the signal lights will turn on but will not flash, and the clicking sound in the cabin never makes a sound (signal lights front and rear stay on solid until the signal lever is turned off). I was wondering if there may be an issue with the amount of draw of the led's vs what the stock signal did. So i unhooked the LED signals and held a working front signal bulb to the wiring and the lights would randomly signal and the clicking sound would happen in the cabin. So I'm wondering if anyone else has converted to LED's and had a similar issue? Do I need to wire in a resistor or something like that? Any help is greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Miles Posted April 30, 2015 Share Posted April 30, 2015 (edited) Your are close. Replace the old analog flasher with an electronic flasher when using LED bulbs. It will connect to the same wire your existing flasher uses, but the electronic flasher has a pigtail for a ground. This may be of interest: http://forums.hybridz.org/topic/122167-riddle-me-this-72-turn-signal-woes/ Edited April 30, 2015 by Miles Quote Link to comment Share on other sites More sharing options...
adrenaline child Posted April 30, 2015 Author Share Posted April 30, 2015 Thanks a lot! would a unit like this one be what i would need? http://www.ebay.com/itm/2-PIN-PRONG-TERMINAL-LED-FLASHER-ELECTRONIC-RELAY-SWITCH-TURN-SIGNAL-LIGHT-12V-/330981964018?fits=Model%3A240Z&hash=item4d100ff8f2&vxp=mtr Quote Link to comment Share on other sites More sharing options...
Miles Posted April 30, 2015 Share Posted April 30, 2015 Yes. I got mine at Oreilly autoparts Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted April 30, 2015 Share Posted April 30, 2015 I used this one. Literal plug and play: https://www.superbrightleds.com/moreinfo/flashers-load-resistors/cf13jl-02-led-bulb-electronic-flasher/783/837/ Quote Link to comment Share on other sites More sharing options...
Miles Posted April 30, 2015 Share Posted April 30, 2015 Somewhere I recall seeing an electronic flasher that had an adjustable flash rate for LED lights. Quote Link to comment Share on other sites More sharing options...
Miles Posted April 30, 2015 Share Posted April 30, 2015 (edited) Here is a good write up on LED bulb replacement in 280Z: http://www.nearwood.net/category/cars/ Scroll down to about 1/3 of the page. Edited April 30, 2015 by Miles Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted April 30, 2015 Share Posted April 30, 2015 Heh. That's my write-up. I forgot I had to run a new ground. So I guess not plug and play. The fact I could use the stock connector was a pleasant surprise though. 1 Quote Link to comment Share on other sites More sharing options...
adrenaline child Posted April 30, 2015 Author Share Posted April 30, 2015 Thanks so much for all the help! Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted April 30, 2015 Share Posted April 30, 2015 (edited) It sounds like the original flasher had issues to begin with, where the flash rate was slow with conventional bulbs installed.You are correct that the LED has a lower current draw and will not cause a conventional bi-metal flasher to operate. Even some early "electronic" flashers may not flash at the correct rate, since some of them still relied on the higher current draw of a conventional bulb.I bought a flasher years ago when I replaced my tail light bulbs with LED that was meant for a "hybrid" system, that still had conventional bulbs and LEDs installed on the same circuit. I'm not sure how much I believe this special designation/application. The one I bought didn't require any additional wires, IIRC. If it did it was a simple ground and easy to install. Edited April 30, 2015 by Six_Shooter Quote Link to comment Share on other sites More sharing options...
Miles Posted April 30, 2015 Share Posted April 30, 2015 (edited) Here is an adjustable flasher designed specifically for LEDs: hotronicsproducts.com/product_info.php?products_id=5&osCsid=fa310277fd5842b79683c8a4cb880e14#.VUK4DpPUfYg Edited April 30, 2015 by Miles Quote Link to comment Share on other sites More sharing options...
Miles Posted April 30, 2015 Share Posted April 30, 2015 (edited) edit Edited April 30, 2015 by Miles Quote Link to comment Share on other sites More sharing options...
