Heater Hose Connector?
Hi all,
I've got a rookie mechanical question for you... What is this connector called?
[NOTE: This isn't my vehicle and I only Googled this image for purposes of this post.]
It connects the outbound water from the engine block to the heater core behind firewall. The reason I ask is because (1) I'm new to cars and learning as I continue to work on my project and (2) I'm getting ready to order new hoses and would like to replace that particular connector. I presume it's common enough to order from AutoZone or Summit?
Thank you!
Why do you want to replace the connector? unless yours is corroded badly. And it's just a 90* fitting, i think 3/4" or 5/8" barbed one side and the other is some thread npt or bpst. You can probably pull it out and head over to a plumbing store and get it. They can at least measure it for you so you know what to look for.
