Need dashboard wiring help
stopped working on the car late december and had all connectors marked
that this situation would never happen :wacko: phone died and all the pictures i have taken
are gone with the wind :( the only bits i cant figure out are the ignition switch
and two other things. maybe someone can help with the connection order and wire color ?
car is a 1972 240z
location is left driver side
location is behind steering column
ignition switch
Edited by gacksen
Do you have an electrical schematic?  If not look around Hybridz or do a google search and download a pdf copy of the schematic. Some members here have colorized the schematic making it easier to read.
With a pdf copy of the schematic you will be able to enlarge it making the switch connections easier to read.
See attachments.
BE Body Electrical.pdfFetching info...
Edited by Miles
