spitsnaugle Posted September 10, 2015 Share Posted September 10, 2015 (edited) Hi all, In progress of building out an LS1 for my 240z. Currently: LS9 Cam + LS2 front cover + holley carb + intake Using JCI mounts for the swap. (yet to arrive) Electric water pump and no other accessories. Has anyone mounted an alternator low passenger side? If not, anyone run a mini alternator as the only accessory on the driver side? What mount & alternator did you use? Here is my current setup - I fear the alternator sticks out too far: Threads I've already looked into: http://forums.hybridz.org/topic/72741-whats-wrong-with-this-bracket/ http://forums.hybridz.org/topic/49579-mini-alternator-with-6-rib-pulley/?hl=alternator Edited September 10, 2015 by spitsnaugle Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 10, 2015 Share Posted September 10, 2015 I have not. I think the conflict is with lower radiator hose when using stock water pump. I don't see the lower radiator hose port on yours.... I was looking at the Front Runner after-market accessory setup the other night when I was fantasizing about a turbo build, and your setup looks similar. You trade off narrowing your setup at the cost of lost room between the water pump and the radiator/fans. You might be crowding things in front already(?). Pretty motor. Quote Link to comment Share on other sites More sharing options...
crapforum Posted September 11, 2015 Share Posted September 11, 2015 Whats with the carb and truck oil pan? Looks like you alternator will fit on driver side, but will be very very close. Quote Link to comment Share on other sites More sharing options...
spitsnaugle Posted September 11, 2015 Author Share Posted September 11, 2015 @keith - I was eyeballing the gap between your alt. and frame rail, looked pretty tight. The lower port jots out the bottom of the water pump at this angle: http://static.summitracing.com/global/images/prod/large/mez-wp119u_w.jpg You got any spare r200 LSD 3.9 rears you'd be looking to get rid off? I've seen your stash! @crapforum Thats the oil pan that came with the engine when I picked it up (used on craigslist). Thats also spare carb I had laying around, but it will be running a holley 750. I like simplicity and a lack of electronics. The purpose of this car will be about 75% drag racing 25% autocross. It'll also be running a reasonably built 700r4. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted September 11, 2015 Share Posted September 11, 2015 No, I will hang onto my diffs until I give up on R200s or give up on Z cars-they are just too hard to find. Have you checked on the price of Will's 8.8 kit? If I knew what I know now, Id have put a solid axle in my car from the get-go. But I don't want to put my car down and start over. I've still got some frustration absorbing capacity. Keep cruising eBay for R200s and post wanted ads here. I'm not buying any more, so you needn't worry about me sniping them. Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 12, 2015 Share Posted September 12, 2015 With the JCI mounts my car is running a stock LS1 alternator low on the drivers side. JCI did the install so they know what they used to make it work. Quote Link to comment Share on other sites More sharing options...
EastTnZ Posted September 12, 2015 Share Posted September 12, 2015 I'm running JCI mounts and a ls1 alternator mount with a '01 truck alternator low on the drivers side of my 5.3 Quote Link to comment Share on other sites More sharing options...
