Anyone running a top mount turbo on their SR?
jparker893
Blew my turbo on the way back from SoCal. Rather than buy a replacement turbo, I figured it's time for an upgrade.
So I did some research and bought the ISR(formerly know as ISIS) Performance RS3871.
I'm planning on doing a top mount set up and haven't seen any info on what will and what
won't work fitment wise. Is it their any issues that I need to worry about?
I've seen photos of top mount set ups on the interwebs so I am just
hoping is super easy and all I have to do is buy the top mount manifold
and the supporting mods.
BTW: these are the turbo specs
Compressor side 3" inlet
Exhaust side 0.64 A/R turbine housing, Results:
This turbo is rated up to ~380hp.
  • 3 weeks later...
He means the motor had to physically be raised due to wastegate interference with the steering column. I ran into the same issue with a sr20 bottom mount setup. The steering column was going directly through where the turbo sits. So I had to go top mount Everything else is being fabbed up, so it'll be a custom fit for me.
  • 5 weeks later...
