OS GIKEN CLUTCH KITS
Rob L
I have done the search already and unless google is slacking , there are no threads on these clutches in this forum !!!
So now ...has anybody used these clutches
http://www.rhdjapan.com/os-giken-ts3b-multi-plate-racing-clutch-kit-nissan.html
This is what whitehead performance has to say about these clutches
http://whiteheadperformance.com/products/os-giken-ts-series-triple-plate-clutch-kit-ts3b-ns081-cc3-datsun-240z-260z-280z-280zx-l24-l28-l28et-copy/
and thats all the info i can find ...
White heads article says it can be used on the street, I would like to know if there is anybody who has actually used this on the street ....
I want a good clutch ... i dont care if its over kill for my needs...i just want to know if its streetable or an on/off switch.
I have run clutches from Ottawa Clutch, right in your own backyard. They will set you up with whatever your needs are for a deccent price.
As for off the shelf...I have also used ACT clutches....had a 6 puck sprung clutch in a 3.0 liter turbo stroker setup. Reasonably priced and held up to a lot of abuse.
Edited by DREW RBZ
^^^ thanks for the tip...I was looking at act too ...I'm looking to build a turbo L6 who did your bottom end ?
I'm still looking for specific info on the os giken clutch too ...hoping somebody in here has used one to hear first hand experience about them .
Thanks guys ! Sounds like there pretty stealth.The reason i wanted to start this thread was because after searching these clutches... reviews for other  cars people were complaining about chatter . There is a couple vids too but could just be install errors or who knows .
I've got an OSG STR 2CD in my 240Z, driven on the road and used on the track, took a while to get used to the biting point for road driving and still occasionally stall but no major dramas with it
Mine does rattle/chatter when the clutch pedal is depressed but its a characteristic of the unsprung clutch cover design, I believe sprung covers are available for some of the OSG range
My advice for what its worth, speak to OSG and tell them what your needs are and they'll recommend a clutch, when I contacted them they didn't offer an STR 2CD for the L series engine but in their opinion it was the best clutch for my needs so they said if I'd like one they'd put me a kit together, good people to deal with :-)
  • 3 months later...
I'm with Drew on this no need for osgiken I own the car he previously owned the 3l stroker turbo. The act held lots of abuse. When we finally swapped to z32 tranny we ended up with a new disc from Ottawa clutch holding 400 hp and no slip 6 years they also surfaced and balanced highly recommend.
