tooquick260
Here is the last dyno run we did to tune the car. It is a blast to drive. There are 29 pulls on this zip drive. You can just look at the last 3-4 pulls as they are the final tune.
225hp with 255 tq on the dyno. Think I am conservative enough on tune for longevity.
Still need to work on decel, and initial tip in. Had multiple issues to deal with at the dyno. Kept losing power to the TPS(was the connection being loose on the spade to fuse panel). Blew coupler off did not know it for first 10 pulls. Pulled the power to 3 injectors by accident while closing the gaps on spark plugs. Had the vacuum lines to the boost controller wrong, hence could not build boost. Thats how it is when you don't finish things you start, or finish things others don't. Have to look over everything.
Data Log Zip File.zip
  • 7 months later...
