joem64 Posted November 27, 2016 Share Posted November 27, 2016 Need to find a source for the stock nissan oil galley plugs for a 280ZXT block. I had removed the plugs myself, and my machine shop didn't realize they were needed(they work primarily on american engines) My fault, on several counts. So, i'm just trying to find a source for these friggin things... anyone have one? Just want to tap them in, and start the final assembly process. thanks, joe in WI Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted November 30, 2016 Share Posted November 30, 2016 I tap mine and put Allen head NPT plugs in. 3/8 or 1/4 can't remember. Be careful with the front one, it can block an oil gallery and you may need to grind it flush. Quote Link to comment Share on other sites More sharing options...
fraz Posted December 1, 2016 Share Posted December 1, 2016 3/8 npt. You need to drill it out to 9/16 before tapping it. 1/4 npt only just scratches the thread in and the plug won't be tight enough Quote Link to comment Share on other sites More sharing options...
zbloke Posted December 1, 2016 Share Posted December 1, 2016 Need to find a source for the stock nissan oil galley plugs for a 280ZXT block. Have you tried your nearest Nissan dealer? Pretty sure the part no. is 11024K0100 Quote Link to comment Share on other sites More sharing options...
TimZ Posted December 1, 2016 Share Posted December 1, 2016 I tap mine and put Allen head NPT plugs in. 3/8 or 1/4 can't remember. Be careful with the front one, it can block an oil gallery and you may need to grind it flush. I thought I remembered this happening at the rear of the block - at any rate check both to make sure you don't block oil flow to one of the mains. Quote Link to comment Share on other sites More sharing options...
