datsun240z66gt2 Posted January 2, 2017 Share Posted January 2, 2017 Anyone know where i can find head gaskets that use aluminum O Rings at top of Chamber Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 3, 2017 Share Posted January 3, 2017 Whittle Rings are stainless. I don't know of any block sealing head gasket that uses anything but stainless steel or monel/inconel fire ring, Quote Link to comment Share on other sites More sharing options...
TimZ Posted January 3, 2017 Share Posted January 3, 2017 Whittle Rings are stainless. I don't know of any block sealing head gasket that uses anything but stainless steel or monel/inconel fire ring, Yep. Is it the separate gasket/fire ring combo that looks like this? Quote Link to comment Share on other sites More sharing options...
datsun240z66gt2 Posted January 3, 2017 Author Share Posted January 3, 2017 Yep. Is it the separate gasket/fire ring combo that looks like this? . This is exactly what it is. Quote Link to comment Share on other sites More sharing options...
datsun240z66gt2 Posted January 3, 2017 Author Share Posted January 3, 2017 Yep. Is it the separate gasket/fire ring combo that looks like this? Tim if you please post part numbers. Quote Link to comment Share on other sites More sharing options...
grannyknot Posted January 3, 2017 Share Posted January 3, 2017 Okay, I'm going to ask the dumb question, how are these better than average HG's? Higher compression? Quote Link to comment Share on other sites More sharing options...
TimZ Posted January 4, 2017 Share Posted January 4, 2017 Tim if you please post part numbers. Gasket 11044-E4621 Rings 11045-N3120 To answer your other question, they have pros and cons Pro: they are MUCH harder to "blow out", so they are more tolerant to high cylinder pressures and detonation Con: they are MUCH harder to "blow out", so they allow you to run with more detonation. On a poorly tuned engine this can mean breaking ring lands on expensive pistons instead of just having to replace a $40 head gasket. Quote Link to comment Share on other sites More sharing options...
malibud Posted January 4, 2017 Share Posted January 4, 2017 So that is an O ringed block ? or are the rings in the head gasket ? Quote Link to comment Share on other sites More sharing options...
TimZ Posted January 4, 2017 Share Posted January 4, 2017 So that is an O ringed block ? or are the rings in the head gasket ? The block is machined to receive the stainless o-rings Quote Link to comment Share on other sites More sharing options...
datsun240z66gt2 Posted January 4, 2017 Author Share Posted January 4, 2017 . This is exactly what it is. THANK YOU SO MUCH I FOUND HEAD GASKETS ON E BAY ANY IDEA ON THE O RINGS Quote Link to comment Share on other sites More sharing options...
TimZ Posted January 4, 2017 Share Posted January 4, 2017 THANK YOU SO MUCH I FOUND HEAD GASKETS ON E BAY ANY IDEA ON THE O RINGS Not really - Google didn't turn up too much. Maybe try Courtesy Nissan to see if they can scrounge a set up? Quote Link to comment Share on other sites More sharing options...
