Enginerd81 Posted January 8, 2017 Share Posted January 8, 2017 Quick and easy question - I'm putting my trans back together, disassembled to reseal/gasket/oring to get rid of leaks, and wondered if there is supposed to be anything used to secure the boot that on the shifter: http://www.zcarsource.com/uimages/product_photos/clutch/1410169.jpg The factory manual doesn't show anything and there was a zip tie on it when I disassembled it. Wondering if it supposed to be sealing all on its own at the base or if others have used a hose clamp/CV boot clam or other. Thanks Bryan Quote Link to comment Share on other sites More sharing options...
Ben280 Posted January 8, 2017 Share Posted January 8, 2017 I've had good luck with a zip tie. You could go with something heavier if you were worried, but I don't think there is a need. Quote Link to comment Share on other sites More sharing options...
BJSZED Posted January 9, 2017 Share Posted January 9, 2017 I put a new boot seal on, didn't use anything...works fine. If you are re-using the old one, might be looser. Ziptie probably best Quote Link to comment Share on other sites More sharing options...
