Persephone '81 280ZX
rayaapp2
DatsunMotorSports Project Persephone
This is Nathan's (AKA Gollum) old 280ZX.
12512805_1096985410320833_84948899650999
12670813_1147184685300905_89720134022357
I purchased the car from him back around Nov of 2014 and have been caring for it since. The timeline here will be a bit fractured but hopefully not disorientating.
12565423_1096985416987499_74837002723919
I came with a few buddies, and we shoved an L28e in it, and drove it back the same day!
Ive made progress, and stepped backwards more than a few times, and I dont expect that, I will find myself on the same path I am on now in the future with this car. Though the point of this car is that I have a backup car of sorts. But being one of my cars, I tend to go overboard. The car is still in the smog system here in Ca so I am also limited by that factor.
I got as far as to get the L28e in and the car smogged, and then the head gasket on the L28e blew out. The engine had been sitting for many years prior to me using it so it was not unexpected.
So I installed an L28et.
Smog Regulations allow me to install an 81 turbo as a replacement in an 81 car that had that option!
I also installed a Chinese Aluminum radiator and dented my hood!
12512313_1096979723654735_47574087034235
I converted the car to a Z31 ECU at some point in time, I dont recall exactly when, but it was maybe 6 months after the L28et went in. I was having nothing but issues with the first turbo engine, and I was beginning to suspect a bad hole. I lost power and #5 went dead prior to the big turbo swap. After moving to Sacramento I just assumed the engine had had enough abuse so I installed a second engine I had around and it ended up being a mistake! I had installed a set of Doctor Injector Flow tested and cleaned injectors
Thanks to Marc Pickering for this Wonderful Writeup for the Z31 to a L28et
280ZXT TO Z31T ECU SWAP GUIDE.pdfFetching info...
12510265_1096977753654932_57075338144049
Turns out #5 injector took a dump, so it was off to Doctor Injector under warranty.
But it was time to escalate again!
NISTUNE!
I opted for a Nistune with an 89 Z31 ECCS ECU and the Feature Pack to include E85 Flex fuel as here in Sacramento Ethanol stations are everywhere!
12742507_1112004632152244_13561955394240
12592625_1147184665300907_58244379306767
Yes, I installed a front mount intercooler! Many other small changes have been made. You will note the TechnoToyTuning camber plates, you will find T3 coil overs and adjustable tension rods under there as well. The lack of a power steering pump should also be apparent. A 78/79 S130 Manual Rack has been installed. It was interesting to note that a S30 RHD rack is the same part number! However S130 rack bushings are extremely difficult to find! A 1" Nissan BM50 MC has been installed to replace the stock 15/16" MC unit. The Ignition Coil and Ignitor will also stick out, but this last picture still shows the NGK plug wires which ended up being a huge source of ignition headaches! The coil is a GM HEI from a 96-99 Chevy Votech Truck engine, and the ignitor is a Nissan PRW-2 ignitor.
"For the 280ZX Turbo dead ignitor:
Here's a better ignitor upgrade than the now common Chevy HEI swap. The non-Z31 VG30 and VG33 (Maxima / Pathfinder / Quest / QX4) engines use a PRW-2 ignitor that wires up almost the exact same way as the 280ZX Turbo and Z31. These can be easily found in the junk yard (in front of the distributor base) or parts store.
Step 1: Run the 280ZXT BLACK WHITE STRIPE wire direct to the coil positive.
Step 2: Run the 280ZXT YELLOW wire (ECU signal PIN5) to the right wire on the PRW-2 (GREEN RED STRIPE).
Step 3: Run the PRW-2 GREEN left wire to coil negative.
Step 4: Run the PRW-2 BLACK center wire to body ground.
Alternatively you can use the Z31 ignitor, the only wiring difference is the ground and ecu input signal wires are swapped. So on the Z31 ignitor the BLACK ground wire is on the left and the GREEN BLACK STRIPE input signal ECU PIN5 is in the center.
12552601_10209089696621203_3651401946216
XenonZcar PRW-2  "
Credit to Marc Pickering
12920481_1147184838634223_41263954523013
12495090_1149493415070032_70305953051073
I Had Troy Ermish machine the stock 5spd Bell Housing for a KA transmission, modified the stock mounting member, and shortened the driveshaft.
12745472_1110409682311739_41513208226059
12717161_1110409738978400_14837491827608
I installed the tripod axles, and eventually pulled the whole sub frame out for a later 83 turbo with the late model brakes and control arm geometry prior to Z31 initial EFI swap.
12540705_1096959076990133_52348273359299
12509247_1096948676991173_82473116064355
Upper is 82-83
Lower is 6/78-81
12417708_1096948686991172_48078158358213
And Eventually Z31 CLSD went in just after NISTUNE was installed.
12733534_1110409762311731_60054846036609
Keeping an old L28et working well on a stock stuff system was becoming a royal pain the butt. With the Z31 ECU swap in place and NISTUNE on the way it was time to address the TURBO!
And honestly the Garret T3 I was using was from a 85 Z31 with water cooling and it was starting to show its age. But when you have a HKS GT3037 (a big compressor version of the Garrett GT3076R) just laying around because it was too small for another project, why not use it?
12928293_1151327701553270_85514306097386
I got online and went to ATP and ordered up a .48 Turbine housing with a swing gate housing and a few other mockup parts. I plan on Changing the Turbine housing out once more to a .83 as of current.
12923154_1151327981553242_74116526238556
A stock T4 housing next to the big one.
12963480_1151328028219904_21532222511396
13177293_1166872393332134_78642947403573
Mocking up the turbine housing, I was forced to use a 1" SS spacer. The manifold was ported, and the studs removed.
13174154_1166872359998804_49426132851869
13178720_1166872506665456_36520135862653
Notice the stock down pipe is still on there.
Next was the Fuel System
Palnet was kind enough to put a rail together to my specifications.
12963532_1152030408149666_13890430443737
Dual Feed in and center out on Denso 440cc Injector 11mm O-ring.
1982124_1152030471482993_264696827446223
12936488_1152120801473960_39084685695877
12991044_1152120864807287_88041103843454
This was mocked up on a spare L28et. I have 5 of those for this one car.
13177953_1167343566618350_90225980099337
Accell 9.5mm custom wires with MSD ends.
13139340_1167343583285015_29217892310286
The stock FPR wasnt doing it.
Nismo FPR!
13265869_1181065265246180_52037155996666
It was here that I finally realized that the stock fuel pump was hitting a wall at 4500rpms at 10psi of boost.
So while in Perris Ca while down for the 2016 MSA Show I located a Bosch 300LPH@5Bar fuel pump and hunted down all the needed hardware with some help from TonyD, JeffP, Frank280zx, and Silvano!
A couple pictures at Tony D's Driveway
13319720_1181065288579511_50654333560832
13312669_1181065315246175_12533470291310
On the way home from Tony's place though trouble struck. The car was having heat issues on and off even on the E85 the whole time I was down in socal. It pegged out on the grapevine. 230F. I was able to slow down and coast it cool, but by the time I hit the bottom of the grape vine it was 110F outside and the car was refusing to cool below 210F. I cruised the whole way home(hours more), making only one stop in Kettleman city for food and to attempt to cool down again. It did cool down, but it was for a but a few miles and the car was back at 210F. The plan was to use this engine as a mule anyway so I was not concerned to much. It would be a few more weeks before I was able to figure out that the radiator had plugged up with rust from the block! I ended up flushing everything and installing a new radiator. The cars normal temp with 100%Dexcool is about 165F under load and it was finally back there. Sadly the engine survived but 1 more week and one trip to work 2 miles out and the head gasket blew and shoved all 2.5gal of coolant through 3 and 4... that was a smelly cloud! The coolant system was under 25psi of pressure!
I cleared the cylinders out on the side of the road, and limped the car back to the shop!
Turns out all that extra heat and a sub par block decking took its toll. The bearings, pistons, and head all checked out fine amazingly.
Well except this quench pad
13912463_1222328831119823_57204232824591
13876579_1222328747786498_10055408922833
13680673_1222328791119827_48413790948264
That damn coolant port in the center got me good.
So Im prepping the next engine
13900215_1225999644086075_82602183359224
It was time to modify the coolant passages in the head though.
13907110_1225999664086073_70343994574611
13876681_1225999677419405_91658689580988
13912856_1228190143867025_29271388409425
Yep drilled down through the flash casting!
I warped the old exhaust manifold so I started working a new one.
13920745_1230499213636118_63936863818831
13935069_1230499196969453_70062117349909
13891881_1230499176969455_12306937884746
The car as it sits for now.
The Engine components are all at my machine shop currently for a fresh build.
I have many more plans, I just bought a S13 rear sub frame, S15 front spindles and a some cheap mockup coil overs.
Stay Tuned for some epic disaster or lots of fun!
Edited by rayaapp2
I took some measurements, I have a rough plan in place. I have to have the subframes shipped up to me from SoCal. After seeing all that JeffP went through to keep his stock subframe in, and all the mess that is getting the geometry correct on the stock subframe... not to mention a total lack of options for brakes and stuff... Im over the S130 setup. I already have all the Z31 outter hubs, axles, and the vented rear brakes all collected for the stock sub frame and Im probably going to give them to a friend of mine that could still use them. Franks Z31 axle writeup has some issues, he doesnt mention in there that he is using Euro stuff! Its not the same. JeffP figured out the mess of parts needed to make that all work together using US model parts at least. Anyway, here are some pictures of where I am at... Just gutted the rear out.
15977609_1388508834501821_88348273490308
16174795_1388508861168485_76753569162408
16105802_1388508877835150_31256609139935
Im thinking I can drill out the spot welds that hold this box frame to the rockers, and the floor. Ill leave the box frame under the tunnel and console, so Ill have to cut straight down through the box frame on both sides. Ill have to make a new panel to the floor from the new position of the box frame. Ill work out the re-informent of the center tunnel after I position the new sub frame mounting pins in.
16105579_1388508917835146_66223256109021
16002816_1388997121119659_51811292023030
Edited by rayaapp2
Some inspiration/research
http://www.takkun.net/dri-z-101.html
http://www.takkun.net/dri-z-323.html
http://www.cardomain.com/ride/2281236/1981-datsun-280zx/photo-gallery/
That is an effective way to do it... easy too, but not how Im going to do it.
22812364050_original.jpg?v=0
22812364051_original.jpg?v=0
22812364035_original.jpg?v=0
22812364036_original.jpg?v=0
22812364031_original.jpg?v=0
Guy is listed right here in Sacramento. I wonder if he is still around.
Not exactly how I would mount mine at all. Those mounts would simplify this greatly and reduce chances of error in squaring it all up!
22812364030_original.jpg?v=0
22812360248_original.jpg?v=4
Rims seem to suite it well.
  • 4 weeks later...
I stripped most of the car out.
16195298_1391926967493341_23113639978303
16143023_1391926944160010_86794738986513
16603033_1412787645407273_40593759841427
16473883_1412787692073935_87178762958922
16472937_1412787708740600_18907085108600
16472972_1412787728740598_63223616201650
I also took the time to start measuring the front suspension stuff for new parts.
So out with the old
16708220_1414782931874411_32684681448379
In with the new to me.
16641118_1412787615407276_11108197061535
S15 Spindles on crappy coil overs(change for Stance later).
16507922_1412787545407283_38708691868660
16427609_1412787578740613_35760727773376
16508065_1414783081874396_3363899718347316508224_1414783101874394_74725064845582
I got underneath and took a look around to see how the sub frame is laid out under there for myself with a tape measure.
16649023_1414782955207742_64234239345533
16684194_1414782981874406_3729197315387716603070_1414783005207737_6779978843850216508186_1414783035207734_2760078194093816683843_1414783061874398_57173298424754
Last time Ill have this stuff under this car so I napped some pictures.
And then I really dug into it... checking how deep the entire cowl went... which as it turns out is a lot farther than I thought.
16603006_1414783235207714_39470995160086
Tar Removal...
16508892_1414783258541045_5538401436811616640974_1414783298541041_30641239423971
16640758_1414783331874371_3725841447721616602735_1414783361874368_28380087219094
Rust located... pencil sized hole.
16649039_1414783388541032_85405265247494
16508550_1414783408541030_6277795145758516640939_1414783461874358_84957004169008
Transmission back out
16640893_1414783525207685_84907279055509
A real mess now...
16602823_1414783558541015_3840254377426216640604_1414783588541012_83004309998347
These brakes are much larger... but still clear the Rota 15x8 Grids I have. I checked. I am unsure what the final wheel that goes on after will be.
16507960_1414783601874344_68068403973610
16602670_1414783621874342_84454954362970
Bat Sheet Wild Much? I hope not.
16649085_1414783658541005_64871753090314
16681967_1414783635207674_65408493959089
16711922_1415496755136362_23231761220324
16729457_1415496768469694_5070263480299216729355_1415496818469689_37450394216509
My phone gets drunk often and takes blurry pictures...
16684205_1415506668468704_69279435828776
Lovely right?
Well, I got the paint in...
16641072_1419469524739085_21993578563899
So Im off to choose a good epoxy primer.
  On 1/23/2017 at 2:09 PM, BluDestiny said:
I was under the impression that the front 2 mounts line up exactly with where the old subframe mounts.
I think they do, but need to be moved back to get the centerline of the wheel correct. Ill know more when I get my sub frame to the shop and start measuring.
  On 1/18/2017 at 4:45 PM, BluDestiny said:
I would love to see you put those mounts in. I'm at the limit where I can either put an s13/14 subframe in or just do the late model swap like you did.
I took some measurements Turns out those mounts are not going to be the best solution. The sub frame is approx 23" center to center on the rear mounts. After getting the tape measure up there it appears the box frame that incorporates to the the floor frame rails up to the rear box frame structure where mounts are needed is the same width apart and 3-3/8" wide. So these C channel mounts would require that an ear be cut off, and without knowing that the C channel is precisely the same ID of 3-3/8" it seems like a tremendous waste of nearly $200 and that starting from scratch is a much better idea. I know several guys cutting up S130 chassis right now, and Ive ask 2 of them to remove the front sub frame pins, and cut the mounting box for those pins with plenty of meat for me. So with any luck Ill be re-using the stock parts from the donors, but Ive also contacted a local fastener company that says they an get me a M20 bolt in fine thread if needed. As I understand it the fronts should be 5" long and the rears should be 6.5" long, but I have yet to get the sub frame in my hands. My buddy is still packaging it for shipping.
Transplanted a rear S14 subframe assembly years ago for a race two seater S130 and the biggest problem by far was not being able to get the assembly high enough. It's a race car so low is good but it's not a disaster, it's done quite a few laps and drives great. So what I'm saying is don't worry about the detail, it will sort itself out as you go, but get that subframe as high as possible which will involve cutting, patching and welding whatever gets in the way, not just some hammer massaging.
No kit needed, if you can't do it without a kit then seriously you don't have the necessary skills and equipment to do such a job.
  • 3 weeks later...
I hadnt considered how far it would drop from the frame rails(seeing as the stock sub frame hangs no lower than the rails). Thats good to know. Ill have to take some measurements. Im still waiting to get my sub frames shipped up from down south.
I have no interest in paying the money that kit wants. Its not that I cant fab up a mount, I totally can, but the to do so vs just buying something thats is well built sometimes wins. I ended up plasma cutting out the whole rear deck box frame with studs from a donor car for mockup purposes. I might chop it up and pull the pins and mounts from that as they are super clean. I also salvaged a nice cowl area for my car from that donor.
  • 4 weeks later...
  • 3 weeks later...
  On 4/21/2017 at 7:23 AM, 260DET said:
In hindsight some of my posts are not the best but the one above says it all and deserves thanks. My avatar car, S14 suspension front and back.
Do you have any pictures of your work?
Ive been working on the motor lately and havent got back on the rear suspension yet. My main goals at the moment are to get the wastegate plumbed up as Im running an external. But Id love to see another version of how the rear sub frame was swapped. Thanks
No pics taken of mine during the build, it's been a running car for years now so the diff, axles and all the other stuff under there obscures the build detail.
S14 subframe into a two seater, rear S14 mounts match up to an existing body X member, fronts are narrower and a bit back from the OE mounts. So basically you do what is fairly obvious, reinforce where the S14 mounts are going to sit and bolt them in through the floor. Detail will only confuse, you know that something like a suspension subframe needs to be solidly mounted so that's what you do. If you can weld, make brackets and so on then go for it.
The good thing now is that dropped rear spindles are available to help keep the proper rear suspension geometry correct if the car has to be lowered more than the S14 suspension should be.
Nearly forgot, be careful with measuring everything to make sure the rear suspension is square with the rest of the car. I just used the usual measuring tools, when the wheel alignment was done the machine showed .01* out of square when new cars can be several degrees out. A bit lucky of course but it shows what can be done with care.
Edited by 260DET
