Timecode Posted February 4, 2017 Share Posted February 4, 2017 (edited) I want to share with everyone my DIY intercooler sprayer. I went to find a windshield fluid reservoir from a junkyard but couldn't find anything that I liked. Then I ran into this: http://www.midwestbusparts.com/index.php?main_page=product_info&cPath=16_319&products_id=2046 My Streetsmart boost controller controls a relay that powers the built in pump and activates at certain boost pressure or RPM. I made a bracket from cutting up a straight price of aluminum from the Home Depot and bolted it to the factory battery tray and a factory hole in the fender.The size is awesome and it fits perfectly using factory mounting holes. I have two patio mister nozzles each attached to the front license plate mounting tabs. With my setup, if I put them higher than this, the water sprayed all over the hood/engine leaving spots every where. This initially created a syphon when first kicked on as well but I fixed that with a simple anti syphon/drip valve designed for backyard misters. Theses where hard to find ironically and only found them on Alibaba Express and I had to buy a 50 pack for $10 but only needed one. Windshield washer fluid has worked the best when it comes to minimizing water spots under the hood. Alcohol would be better but washer fluid is cheap. I haven't measured the benefits yet but when I do I'll post it, I can't imagine it's not effective. It drains quickly if I set the boost controller to activate it at lower psi, slower if set to higher pressures. Same would go for RPM triggering. This same system can work with a basic switch versus using an electronic controller if so desired. Edited February 4, 2017 by Timecode Quote Link to comment Share on other sites More sharing options...
softopz Posted February 15, 2017 Share Posted February 15, 2017 Really nice ! Quote Link to comment Share on other sites More sharing options...
