Alex.mira22 Posted May 9, 2017 Share Posted May 9, 2017 (edited) Motor specs -L28 3.0 bore block with forged Ross Racing flat top pistons -aeromotive adjustable fuel pressure regulator -N47 port and polished head -pallnet aluminum fuel rail -stock injectors (new) -stock distributor with electronic crane cams ignition and fireball ignition coil (Motor has like 600 Kilometers on it since rebuild) im from Canada.. My question really is... How "simple" is the megasquirt install, I'm confused with the bip373 mod and the stock coil. I plan to run MS2 fuel only for now because my stock wiring and ecu is toast, and I've checked all my ohms and test in the FI bible. I've given up on the stock Efi system, And im also tired of the AFM!! What do I need for this install for fuel only? How do I hook up to the electronic ignition? Or do I even have to for fuel only? 240sx throttle body? I'm confused! I Need help!! Edited May 9, 2017 by Alex.mira22 Quote Link to comment Share on other sites More sharing options...
madkaw Posted May 9, 2017 Share Posted May 9, 2017 Might as well do both ignition and fuel . It's a steep learning curve but it will click if you keep reading. There's lots of reading on this site under the MS section. . Some shy away from ignition but I did it first. Getting ready to do fuel myself. You need to get a direction of where your heading and then come up with specific questions Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 9, 2017 Share Posted May 9, 2017 I plan to run MS2 fuel only for now because my stock wiring and ecu is toast, and I've checked all my ohms and test in the FI bible. I've given up on the stock Efi system, And im also tired of the AFM!! MS is probably more difficult to get working than the stock system, so if you couldn't figure out the stock system MS won't make your life easier. MS will run your engine better, but the stock EFI system is so basic it's essentially a tutorial on how EFI works, in general. Quote Link to comment Share on other sites More sharing options...
Alex.mira22 Posted May 9, 2017 Author Share Posted May 9, 2017 I have done all the research I can, it's been 3 months of googling, searching forums, emails diyobo about ms2 and I just can't seem to understand those 3 questions asked above Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 9, 2017 Share Posted May 9, 2017 You should be using the Megamanual. You can trigger the MS system using the negative post of the coil, just like the factory system does. Here's a couple of pages that cover what you need and other stuff. You don't need a 240SX throttle body. You might be thinking of a throttle position sensor but you don't need that either. You already have a throttle body. Click the blue links for details. http://www.megamanual.com/v22manual/mintro.htm#applic Here's a mention of triggering from the coil - http://www.megamanual.com/ms2/pickups.htm Quote Link to comment Share on other sites More sharing options...
softopz Posted May 10, 2017 Share Posted May 10, 2017 Motor specs -L28 3.0 bore block with forged Ross Racing flat top pistons -aeromotive adjustable fuel pressure regulator -N47 port and polished head -pallnet aluminum fuel rail -stock injectors (new) -stock distributor with electronic crane cams ignition and fireball ignition coil (Motor has like 600 Kilometers on it since rebuild) im from Canada.. My question really is... How "simple" is the megasquirt install, I'm confused with the bip373 mod and the stock coil. I plan to run MS2 fuel only for now because my stock wiring and ecu is toast, and I've checked all my ohms and test in the FI bible. I've given up on the stock Efi system, And im also tired of the AFM!! What do I need for this install for fuel only? How do I hook up to the electronic ignition? Or do I even have to for fuel only? 240sx throttle body? I'm confused! I Need help!! With a motor like that, I would definitely ditch the stock EFI system. You will make more power and the tunability is priceless. Why would you go fuel only ? its literally a couple more wires and you have spark 240sx TB bolt right in space with spacer (to allign linkage or bolts direct with shortened linkage or throttle cable conversion) These answer have all been beaten to death IMight as well do both ignition and fuel . It's a steep learning curve but it will click if you keep reading. There's lots of reading on this site under the MS section. . Some shy away from ignition but I did it first. Getting ready to do fuel myself. You need to get a direction of where your heading and then come up with specific questions \agreed! I have done all the research I can, it's been 3 months of googling, searching forums, emails diyobo about ms2 and I just can't seem to understand those 3 questions asked above Honestly, if you have been truly doing 3 months of research you kinda suck at research haha If ms2 is scaring you I do a plug and play harness system it's perfect for your situation. Check the group forum buy I am currently doing 4 already completed 2. Quote Link to comment Share on other sites More sharing options...
